Question about Saeco Magic De Luxe Espresso Machine
Worn Main Brew Head Gasket
I just want to change the main group head gasket on my Saeco Magic espresso machine..Is this hard to do??Will I need the Saeco Lube to assist with this process?Thanks, John
  • Anonymous Mar 12, 2014
    changing group head gaskets
    Problem Solver:
  • 8 Answers
I use cocktail sticks or similar to remove old seal and then a little sunflower oil to lube the new seal
Posted on Jan 09, 2009
How to change brew group rubber orange gasket on saeco Incanto Sirius
google for USA-Incanto Rondo SBS-RS, E74088 Rev. 03.pdf
it has an exploded view of the brew unit. partsguru has the part.
Jan 30, 2013 | Saeco Vienna SuperAutomatica Coffee...
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
My portafilter is leaking during brewing. seems it can not get as tight as it previously was able too. I have the model with the 3 settings and even on Ristretto, the coffee comes out way too fast and the...
You need a new brew head gasket. They are not that hard to change. Four nuts hold the chrome head on. Once the chrome head is removed the gasket is pulled off then the brew head is cleaned and then you can put the new gasket on. Check ebay.
Feb 06, 2011 | FrancisFrancis! X1 Espresso Machine
When brewing with the X1, water starts leaking from the underside of the top where the brass filter holder connects to the machine. Tightening the 4 nuts did not help.
HI
More than likley its your brew head gasket that is leaking. Take off the 4 nuts you hust tighten and it exposes the brew head gasket. Make sure that you put the chrome piece on the same way you took it off. Clean the head good before you put the new gasket on or you could have trouble.
I would check ebay.
Jan 31, 2011 | FrancisFrancis! X1 - Stainless Steel...
My saeco magic deluxe, doesn't make coffee all the time, it seams the brew group arm is not riseing and the coffee gets dumped in the tray
Sounds like early stage of stripped gears in Gear assembly or faulty Main electronic board. These are the 2 most common problems.
Mar 28, 2010 | Saeco Magic De Luxe Espresso Machine
Brew group stuck in machine. machine will not turn on
You have the dreaded dead electronic board problem.
99.9% of the time your boiler has leaked water on main electronic board and now both need to be changed , not worth the repair my friend.
Mar 21, 2010 | Saeco Magic De Luxe Espresso Machine
The handle is leaking water
Hi
Your brew head gasket needs replacing. They get hard after about 6 months to a year depending on how long the machine is on. if it on 24/7 it need to be changed every 6 months. If turned off daily every year. The gasket is up where you install the portafilter to make espresso. The black ring is rubber and that is what need to be changed. Have one setting right here on my desk.
Nov 09, 2009 | Pasquini Livia 90 Espresso Machine
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Saeco Magic Espresso Maker is leaking
I know I'm probably too late for this solution, but it could be your brew head gasket is cracked if it got too old, the outlet valve is defective/worn/broken or it could be a worn out steamer needle valve. This will appear as soon as the heating element is turned and water expands.
You can get most common maintenance parts in kits on line for about $50 or so for a complete set or individual parts for less than $20; As for the valve stem if it isn't too worn out, you can resurface it carefully with a file and sandpaper.
Jan 19, 2009 | Saeco Magic Espresso Espresso Machine
Portafilter loose in group head
Do you only have the top off or do you take out the boiler too?
if you took out the boiler then i think the holder is in wrong position, make sure the gasket in the holder are in place, if not then the portafilter do not lock tight.
Hope this will help you.
Best regards
/Mirran
Aug 29, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Saeco Magic De Luxe Espresso Machine Logo
158 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
