Question about Allegro DVD Recorder VCR Combo ABR521
Model abv441 Picture flutters when playing vcr tape
Thank you
Charles Seifert
Remove the casing of the unit. You will see a head where the tape runs across. Keeping it powered up, with tape in....There are three screws around the base of the head. With a small phillips adjust the head by turning the screws one by one. If you adjust out too far, the screws will come out completely. Take your time when adjusting. You will notice the picture change with the turning of the screws. The sound will change also. It takes very little adjusting to get it right. Play around with it and it will work in no time...Good Luck
Posted on Dec 16, 2008
I play a tape in my Sony SL-5200 Betamax VCR. It plays normally for about 5-10 minutes and then the picture starts fluttering which lets out this loud buzz on the Hi-Fi audio track and cuts it out to mono....
It could be some kind of tracking problem. The cause could be dirt on the tape head, or perhaps something worn such as a drive belt etc. Check to see if it gets worse or better with the cassette nearly at the end of the tape or at the start of it. Indicating a tape tension problem, on the reels or drive.
Jul 28, 2011 | Sony Televison & Video
Model abv441 need a manual
I did find a manual for the abv341 manual...perhaps there something here that might help you:
https://www.manualslib.com/products/Zenith-Abv341-Series-4031192.html
Jul 02, 2017 | Allegro DVD/VCR ABV511
Picture rolls and the tracking is off.
do the heads need cleaning? sounds like the heads are seriously out of alignment? take off the vcr cover get a philip scrdrv. put tape in. and play. theres an AC head just to the right of the drumhead. jiggle it around gently. u may have to adjust those 3 screws (precison) to put it back in proper adjustmant. also take the tapes u used in that vcr. open the top flap and inspect. are there marks? is there a line going the bottom portion of the tape. if so , it definitely is out of alignment.
Aug 14, 2009 | Philips Televison & Video
Not able to view the picture
You may need to change the input on your tv, and check the output cables to make sure they are hooked up correctly.
Jun 21, 2009 | Allegro ABV511
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
VCR playback sound and pciture don't match
That is a tape path issue. The new VCR has the problem, usually the guide post for the tape sticks out when it shouldn't making the sound late for the picture because the gap between the video head and audio head is wrong.
Mar 31, 2017 | Philips Magnavox 20MC4304 20 in....
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
Televison & Video Logo
97 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Repairing
Computer Repairing
ray gallant
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
