Question about Philips PR1901C TV
Philip pr1901-c121 doesn't power up
It doesnt do nothing i'll hit the power button and i dont hear a click or anything
  • 38 Answers
There are many others. you didnt tell how is it done. perhaps a defective memory IC it could happened that the tv wont able to turn on at the time when you left it in a standby mode. contact a service technician for help. good luck
Posted on Apr 11, 2007
  • 68 Answers
Here is the way to fix it. there is a blue round capacitor. I can not remember the value of it but it is not a normal capacitor. it does not have a positive or negative leg..it is blown you will see it. look in the power setion or the HT section.
Posted on Apr 05, 2007
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
My magnavox pr1901 C121 TV will not turn on.
Check and replace faulty component/s in the main power regulator circuit.
Aug 21, 2012 | RCA Televison & Video
Stereo dont work
needs replaced has internal short or open get good aftermarket cheaper then dealer.
Aug 01, 2012 | Cars & Trucks
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
Constant clicking sound when turned on....no picture....looks like TV isn't on. You only hear the constant clicking. You have to cut power to stop it.....hitting the power button on the TV doesn't...
Sounds like bulb is burnt out. Have replaced its the cheapest way to go. It may be a power board but if its out of its warrenty, then you may just want to buy a new set.
Aug 02, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv doesnt turn on at all
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. The noise is what gives it away. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Jan 23, 2010 | RCA Scenium D40W20 40" Rear Projection...
Philips 60" HDTV Rear Proj NO POWER
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
Apr 07, 2008 | Philips 60PP9202 60" Rear Projection...
P4vmm2 doesnt boot,Y?
Hi yansky, When you turn the computer on do you see or hear any of the following: -Does the power LED turn on and if so for how long? -When you turn you power on listen closely for any sounds like hard drives or fans starting up. -Does anything show on your monitor, if yes what exactly? -When turned on do you hear any beeping sounds from the computer? If you do listen for the pattern of long and short beeps and let us know what they are. If you see absolutely nothing you should try testing the socket the computer is plugged into. Fuses blow, power strips die cords develop shorts so unplug the computer and plug in a lamp to verify you?re getting power. If that doesn?t turn up anything let us know the answers to the questions above plus any other observations and we?ll try to help.
Jan 13, 2007 | EliteGroup P4VMM2 Motherboard
Televison & Video Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
