Question about Uniden DCT646-2 Cordless Phone
DCT 646 I have 2 dct646 phone setups which include 2 base stations and 2 charging stations. What I have now is 1 base station plugged into my wall jack which is a verizon service hooked to it. The other base station is plugged into a broadband modem. At the present I only have 1 phone that will work on my broadband line and 3 phones work off of the original verizon line. How can I make 1 of these 3 phone work with the broadband line ? So that I will end up with 2 phones for each system.
  • saifk5152 Jan 07, 2009
    Keeps on giving the message "connecting" BUT no dial tone.
    Problem Solver:
  • 14 Answers
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Posted on Apr 10, 2009
Gigaset a420 has stopped making or receiving calls
You mean unplugged it from the power outlet or the RG45 wall jack? OK so if the battery is fine and you unplugged the power from the source, then the issue is with either the cord itself or the charging unit. Just because the little red light comes on does not mean it is working properly. Put a multi-meter on the charging tabs to double check for continuity. Sometimes and as weird as this sounds, it just takes unplugging a nearly spent power pack/inverter to finish the job so to speak. If you unplugged it from the RG45 then you need to look at the pins in the RG45 wall jack to see if you inadvertently bent one out of shape.Phone won't work if there's no signal. Wish I could help more. Good luck with that issue.
Dec 20, 2013 | Panasonic KX-TGA101S Cordless Handset
Phone has been charging but still won't turn on
Let me suggest that you unplug all stations including the base and disconnect base from phone line. Waite 5 minutes and then plug base station into phone line, and plug all units in again. Most have an automatic procedure of finding all the remotes if yours has manual method do that.
Sep 22, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
No I a looking for a uniden DCT 646-3 telephone manual
you can download it from here
http://www.uniden.com/ pdf/DCT646-2om.pdf
gud luck
Sep 07, 2009 | Lands Phones
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Aug 21, 2008 | Computers & Internet
Phillips phone cd445
On the hand set:
- menu button - ADVANCED SET - REGISTRATION - base 1
- pin # is 0000 (default)
On the base station and the base station handset - press and hold for at least (3) seconds, at the same time:
- on base - the intercom button
- on base handset - menu button
It's in the manual but you need a magnifying glass to read it.
Dec 30, 2007 | Lands Phones
Base station
1. press menu key
Oct 12, 2007 | Polycom SoundStation 2W (2200-07800-001)...
My DCT646-2 no one can hear me.
take it apart and clean the mic with alcohol. (I took out a black round cover it had on top to reduce eco)
Worked for me.
cheers,
Oct 04, 2007 | Uniden DCT646-3 Cordless Phone
Blinking lights
The blinking cordless handset seems to be your main issue. IT should not continue to blink after a start up. I think if you replace the handset and sync it to your base station, your problem will be resolved. The T7406 phones are not the most rugged handsets. IF this unit was dropped, a lo of your symptoms make sense.
Jan 15, 2007 | NorStar T7406 Cordless Phone
Uniden DCT646-2 Cordless Phone Logo
167 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
