Question about Vacuums
How do I **** the air out of a storage bag?
I have storage bags that need to be put away, but I do not remember how to set my Kirby G-six to **** the air out of the bag.
  • 35 Answers
Facing the front of the machine,turn the belt lifter knob counterclockwise till it stops.Lift the headlight hood and unlatch the brushead from the machine.Place the large end of hose to machine,and lock it down.You are now ready to remove the air from the bags.
Note:Anytime you have to remove or replace the brushead,make the belt lifter knb the first thing you turn when removing,and the last thing you turn when reinstalling.It will save you alot of confusion in the process.
Posted on Dec 17, 2008
I have a Kirby G4. I have noticed the last few days when trying to vacuum that it is blowing more than it is sucking up. I put on a new bag to make sure it wasn't too full. I also put on the hose and...
take the mini emptor off(plastic piece on bottom of cloth bag) this is done by rotating it away from the body of the machine. There is most likely a clog there. Also take the brush head off and inspect fan for chips or cracks this will also reduce suction. let me know if you need further assistance
Apr 08, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
I would check to make sure he put the filter bag in correctly.
Dec 16, 2009 | Vacuums
I recently put a new bag in my kirby and now when i turn it on, it will not pick up anything
see if you connected it or install it correctly, see if there is any leackage of air, see if it is air tight, the reason is that the air cannot vacum because there might be some open connection between the bag and the air exhaust of the vacum
Nov 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G3
Take the front of the kirby off (the part that has the brush roller in it) and look in the big hole where the fan impeller is. Most likely this plastic part is cracked and needs to be replaced. Just turn the metal rod sticking out of the hole and the outer ring with the fan blades on it will be cracked off of the inner piece. It is a cheap part (usually $12-$15) but getting to it is not for the mechanically disadvantaged.
Sep 07, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How to use air pump attachment kirby sentria
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
Jul 26, 2008 | Kirby G6 Bagged Upright Vacuum
Is there a reusable bag for a Kirby Gsix
Kirby salesmen have told many that the new polypropalene bags are reusable, however they from what i can tell are not. sure you can empty them like you could any other bag but filtration is going to be greatly reduced as well as air flow which will greatly reduce cleaning ability as kirbys need air flow to work properly. also reusing these bags could possibly damage machine since it is having to work harder.
Apr 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Upholstry set up for ultimate g kirby.
Remove the entire cloth bag assembly and put the hose on the side where the bag came from. Remove the power nozzle and put the intake guard onto the front. (this is in your attachment set...the only one with little hooks that sit on the bar in front) You can change from the long handle to the short if you'd like also. You get the handles off by pushing the "seatbelt button" located at the rear bottom of the handle and pulling the handle straight up and out. Now, put your spray gun on the hose. Don't forget the little suds nozzle that goes on the end of the spray gun. I like to use a half and half solution of Kirby shampoo and water in the gun. It makes a nice dry foam that only wets the surface of the furniture. If you use more water, it takes longer to dry.
If you need a manual (book or DVD) for your Kirby, try this link....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped...
Marci
Mar 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G 6 but it only blows air out, no suction. Also how do you detach the cloth bag to wash it?
I have the solution for the cloth bag laundering process...
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEA...
It should be helpful. :0)
The Tech Drive problem SHOULD be able to be fixed easily and fairly cheaply by a vac shop or Kirby distributor. There is an adjustment that needs to be made, but it shouldn't require purchasing any parts.
Marci
Nov 17, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
