Question about Coffee Makers & Espresso Machines
We have a Krups F408 coffee mill. The electrical chord needs replacing, as it was burned by one of our stove elements. How do we disconnect the bottom of the mill to access the the chord connection?
SOURCE: krups coffee machine
The krups website does have a listing for where to send in for service in China,. That website is www.krupsusa.com
Posted on Jan 04, 2008
SOURCE: Krups 203-42 Electric Blades coffee grinder
i HAVE THE SAME QUESTION.
Posted on Feb 07, 2008
SOURCE: Instructions Manual f. Krups Coffee Machine963
Solved this problem simply by trial and error attempts!
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: krups fmf 5 water leaks from
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Posted on Jan 06, 2009
SOURCE: Krups F-229 coffee maker repair
SmallAppliance.com
Posted on Jan 20, 2009
My Krups km9008 won't pour coffee when i push the button
Hi Beth
Could be several reasons. heating element or pump is burned out or it needs cleaning with vinegar to remove hard water deposits. If you can hear the water being heated. put two cups of vinegar and the balance water in the reservoir and let it soak and then see if the brew cycle will work. We hand to run this through ours 3 or 4 times to get ours to work again.
Sep 03, 2016 | Krups Km9008 Cup On Request Programmable...
How to open repair Krups EA8010
have problems with the mill hack, how can I repair it
Jul 15, 2012 | Krups Coffee Makers & Espresso Machines
Hi, i have the krups 203 coffee grinder mill. i have misplaced the lid. where can i buy a new one? thanks
Here is the link
http://www.krupsonlinestore.com/product_list.asp?MENU=parts&SELECT=grinders&SKW=acccoffgrind
Jan 13, 2011 | Krups 203-42 Electric Blades Grinder
The heating element in Krups stainless kettle has burned out
the element is avilb on the web / look under small appliances / or better yet use your model # and google it . the cost of element and shipping may be more than your pot is worth . you be the judge . i would fix it but / it may not be cost efective .. hope this hepls **** ..
Dec 23, 2009 | Krups Stainless Steel Electric Kettle...
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Nov 26, 2007 | Equipex PZ-330 Electric Single Oven
Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Aug 13, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
