Paper Wrinkle when Printing
My printer is wrinkling pages in the upper right hand corner when it prints. It puts a crease in every page. It's an HP 3015 All-in-one
  • russ_ayers Dec 16, 2008
    Is that something I can do on my own or do I need to take it to a shop?
    Guru:
  • 829 Answers
Its time you need to change the Tension roller of the printer.
Posted on Dec 16, 2008
Why does it print only partial words?
Are you sure the cartridge is good? And is the paper that you use wrinkle free? Try printing out a test page and see what happens.
Aug 26, 2015 | Canon PIXMA MX892 multifunction printer
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
The printed page comes out creased from the top left of the page to the bottom right.
Download this manual >> http://www.mediafire.com/?i0y9iqnqu79ppcj Go to page #203(6-15) Paper Feeding problems (wrinkles or creases) and follow the troubleshooting steps.
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
Sep 03, 2011 | Brother HL 5140 Laser Printer
Hp 1300 Prints fine but creates a slight wrinkle afterwards on the top left corner of each page. I have blasted the insides of the printer with compressed air whihc made a slight difference.
This could be due to either dust inside the roller shutter or due to paper block which is torn and stuck. I suggest you to get the printer serviced by a near bye service centre.
Good luck.
Oct 19, 2010 | HP LaserJet 1300 Printer
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
PRINTER CRUNCHES AND WRINKLES PAPER WHEN TRYING TO PRINT
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 16, 2009 | HP LaserJet 3030 All-In-One Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
461 people viewed this question
k24674
jasbo
jasbo
