Question about Frigidaire FEB24S2AB Single Oven
I have a Whirlpool GY396LXPS02 slide-in oven/range. Starting last night, the oven will not bake or broil. The oven light doens't work either. The range still works fine. A neighbor of mine suggested changing the "Circuit board" as he called it saying this was apparently common with newer Whirlpool ovens. Anyway, I found the parts breakdown but could not find a "circuit board". I did find a control panel (p/n 8191148) which look slike the actual housing for the controls. I also found a migration control (p/n 975476). Which should I replace?
  • thompsonr Jan 22, 2009
    From what I read, the control panel is the problem. It has the touch pad manufactured inside. The Migration board is connected with a ribbon cable and is probably not the problem. The sites I read said this was very common and repetitive.
    I just disassembled mine and am debating on the repair or replace options....
  • biscuitbaker May 24, 2009
    I have the same problem . The touch screen will not cancel bake or broil. If this is a common problem why are they not having a recall on this unit (GY396LXPS02). I have tried to reset the oven from the breaker box, that trick worked for about three months. Now dead just displays pf (power failure from reset of breaker and clock. Any suggestion to this common problem. Do i have to replace parts or is their a connectivty problem behind the touch screen.
    biscuit baker
  • 1891 Answers
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Posted on Dec 04, 2009
  • 417 Answers
SOURCE: oven not working
It is most likely that the oven heating element has failed, which would be the likely source of the 'bang' you heard, you may also need to check the oven temperature control sensor as this may have gone out at the same time.
Posted on Jan 18, 2010
TheMobilian
  • 8220 Answers
SOURCE: OVEN WONT GET HOT ON BAKE OR BROIL IT HAS GOOD
Might be the limit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 13, 2010
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
diodeic
  • 1622 Answers
SOURCE: I have a slide in
things you'll need:
* Masking Tape And Pen
* Wire Cutters
* Wire Nuts
* Wire Strippers
* Flathead Screwdriver
* Replacement Parts
* Wire Cutters
* Wire Nuts
* Wire Strippers
* Wire cutters
Has one burner on your electric stove suddenly stopped burning? Don't worry. Usually this is a problem you can solve quickly, once you've used the process of elimination to figure out what's wrong. One safety note--always unplug the stove between each repair step to avoid shock.
Instructions
Identifying the problem
Inspect the faulty element to determine whether it plugs into a receptacle, as most do, or is wired directly. If it plugs in, move on to step 2. It the element is direct-wired, move on to step 4.
diodeic.jpgRemove the plug-in element and inspect the prongs: Lift up the front of the element, then pull the element straight out (see illustration). Check to see if the prongs are burned, pitted or otherwise damaged. If they are, you'll need to replace the element and the receptacle.
If the prongs are clean, test the element: First reinstall it in the receptacle and turn on the burner--sometimes an element just needs to be reseated to work right. If it still doesn't heat, turn off the burner, exchange the element with another of the same size and test. If the burner works now, the original element needs to be replaced.
If the element is direct-wired, lift the front of the element and pull it out until you see a white porcelain insulator with clips on each side.
Open the insulator. Wedge a flathead screwdriver under the side of one clip and gently pry. This will pop the clip off. Repeat to remove the other clip. Then separate the two halves of the insulator.
Remove the screws that hold the element to its wiring, using a screwdriver. Exchange the element for another of the same size. Reassemble both elements so no bare wires are left exposed, then turn on the burner. If the new element works, the original one needs to be replaced.
Replacing an element
Take the faulty element to a hardware or appliance store and buy a replacement.
Install the new element in the stove. For a plug-in element, just plug it into the receptacle. For a direct-wired element, screw the new element to its wiring, reassemble the two halves of the porcelain insulator, and snap the clips in place.
Test the element to make sure it's operating.
Replacing a receptacle
Disconnect the old receptacle. If it is screwed to the cooktop, use a screwdriver to disconnect it. If it is held in place by a spring steel clamp, spread the clamp and pull out the receptacle.
Lift the cooktop so you can access the receptacle wiring. On some stoves, you just need to lift the corners to raise the cooktop; on others, you have to push the top backward first, then lift. Prop the top open, using the brace that is attached to the inside of the cooktop.
Remove the receptacle. Wrap the wires with masking tape and label them so you can install the new receptacle correctly, then cut the wires. Take the receptacle to a hardware or appliance store to get a replacement.
Install the new receptacle. Strip the ends of the wires with a wire stripper, then twist the wires together and twist on wire nuts to hold them together. Reinstall the receptacle in the cooktop and install the element.
Tips & Warnings
If these steps don't identify your problem, ask a professional to check the surface switch that controls the faulty element. Occasionally it can go bad.
If the entire stove won't work and the power is on, check the stove fuse. It may be near the surface controls or under the cooktop.
Always unplug your stove between each repair step to protect yourself from accidental shock.
Posted on Apr 14, 2011
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
We have a Westinghouse Continental Electric Range KHB30XKI that was installed in the early 1960's. My mother loves it. Tiny kitchen, slide out burners, space saving. Please help me find elements for...
Do the elements look like the pictures here?
http://www.repairclinic.com/PartDetail/Bake-Element/5300210961/2548 bake element
http://www.repairclinic.com/PartDetail/Bake-Element/5300210911/2183 bake elemenet
http://www.repairclinic.com/PartDetail/Heating-Element/5300210972/1070 bake element
http://www.repairclinic.com/PartDetail/Heating-Element/5300210922/609530 broil element
I hope it is one of the these the first 3 are different bake elements the last one is a broil element that the only pull out elements westinghouse used and i appears all are still available from there on repair clinic
I hope i have helped you to find the element you need,
Gene
Aug 15, 2011 | Ovens
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Feb 07, 2010 | Kenmore Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
Frigidaire FEB24S2AB Single Oven Logo
207 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
