Question about Garmin nuvi 255W GPS Receiver
The part that goes into the cigarette lighter broke on my Garin Nuvi. When I pulled it out, the small metal pieces, and a little glass tube fell out. How do I put it back together?
  • Garmin Master
  • 2,130 Answers
The glass tube is the fuse. There should be a spring and threaded metal barrel with a metal tip that slides through it. Look for these (4) parts.
The spring goes in first, followed by the glass fuse and then the metal tip should pass through the metal barrel. Screw the metal barrel with the tip on the end over the fuse. When you press on the tip, it should push in a little and spring back out. If you lost the pieces, you'll need to purchase another charger.
- Jim
SHARCNET-USA
Posted on Dec 16, 2008
How do I disassemble the center console in a 2005 Ford Expedition to get to the cigarette lighter that fell into the center console.
All of the plastic simply pulls apart, but be careful to pull straight out. The plastic attaching pieces could be brittle. BTW, the whole interior trim disassembles in this manner.
Take your time.
May 02, 2017 | Ford Expedition Cars & Trucks
2000 Mazda Protege lx. A phone charger tip broke, blew the fuse(s) for cigarette lighter, radio, and interior light. I checked and replaced mini fuse's in both interior and engine fuse boxes. Problem not...
There is an alternate problem with the wiring in the cigarette lighter where the wire melts and breaks. If you pull out the cigarette lighter assembly you will see a place where one wire splits into two. Find the damage point and replace the wire with a thicker one.
Feb 23, 2015 | 2000 Mazda Protege
Broken cigarette lighter socket
most auto stores sell universal replacement inserts or go to a junkyard
May 14, 2013 | 2010 Toyota Camry
Took out cable connection charger, that attaches to Garmin NUVI, from cigarette lighter in car and the inside springs broke
that's how you can change the fuse.the piece at bottom of picture goes into the threaded piece 1st.
The piece at bottom of picture goes into the threaded piece. The spring goes into the body of the charger then the fuse and then the
threaded piece with the small piece still inside of it is screwed on.
Should work.
Oct 28, 2012 | GPS
I need to buy a plug for car . It is not charging tne GPS
You can get accessories including the car charger from http://www.gpsnow.com/Garmin_nuvi_255_Accessories.htm
However it's likely that if the car charger is not working that the fuse is blown. The fuse is in the plug that goes in the cigarette lighter socket. To get at it unscrew the ring at the end of the plug. Be careful not to lose the small metal tip. When you unscrew the ring the plug comes apart and you'll see the fuse. You can get replacement fuses at any shop that sells garmin satnavs or car electrical accessory shops.
Before changing the fuse make sure your cigarette lighter socket is working by testing it with the cigarettel lighter or some other accessory.
Jan 14, 2011 | Garmin nuvi 255W GPS Receiver
Car power supply for Garmin nuvi 755t does not work. Not sure if its the Wire, mount Adapter or other.
I assume you have checked the cigarette lighter to be sure it's working.
The most likely problem is the fuse in the power cord/charger. The plug which goes into the cigarette lighter socket has a ring at the end of it. Unscrew the ring, taking care not to lose any small parts, and it comes apart. Replace the fuse and it should be ok.
Dec 25, 2010 | Garmin nuvi 755T Car GPS Receiver
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
2006 VW Jetta 2.5, cigarette lighter does not work for charging (or at all). Fuse box is located under the hood. Which number fuse controls the cig lighter?
For 2006 VW Jetta 2.5, cigarette lighter fuse 20A (yellow) is placed in the fuse box on passenger's side. See picture below:
Sep 07, 2010 | 2006 Volkswagen Jetta
Philips Toaster Oven Model HD4464/A
The glass door of an oven toaster usually are inserted in the metal slot just slightly above the hinges, so it can easily slip out and fall. try replace it with tempered glass which can be found in glass supplies
Jul 29, 2009 | Kitchen Appliances - Others
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Garmin nuvi 255W GPS Receiver Logo
194 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
