Question about Lands Phones
My philips cd440 won't stop searching i have a good phone line because i plugged another phone in... my phone philips cd440 has no phone line and just keeps saying "SEARCHING". I'm using now for the moment my old phone (from the attic) and it works perfectly so I know that theres not a problem with the line just the philips cd440, can any one help ???
richa33
  • 71 Answers
SOURCE: Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Posted on Jan 21, 2009
richa33
  • 71 Answers
SOURCE: philips dect245 searching problem
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
richa33
  • 71 Answers
SOURCE: Philips CD125 Twin Cordless Phone "Searching" problem
Maybe, RF amplifier chip die or antenna broken.
  • 6 Answers
SOURCE: my Philips Cordless phone answer
The handset is not ‘registered’ with the based unit.
By default, the Master PIN is 0000.
  1. On the base station, press and hold The paging key for approximately 5 seconds.
  2. On the handset, press Menu key,
  3. scroll : to ADVANCE SET and press (Menu) OK,
  4. scroll : to REGISTRATION and press (Menu) OK.
    Note: If no action is taken on the handset within 10 seconds, the registration procedure will be aborted. If this happens, repeat Step 1.
  5. Enter the Master PIN when prompted and press (Menu) OK to confirm.
Posted on Mar 20, 2009
SOURCE: Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
Try changing the battery. Try using a new AAA rechargeable battries.
Posted on Apr 02, 2009
Telephone socket fine (tested) but phone keeps searching & saying "out of area""
if you've made sure that the jack is good,by plugging in a known working phone and ensuring that it works, try swapping the line cord between the 2 phones, if that doesn't do it, make sure the line cord is plugged into the correct jack on the back of the cordless phone, there often are 2 of them. good luck.
Dec 28, 2013 | Philips Lands Phones
How can I retrieve or delete a voice message?
You're apparently subscribed to a voicemail system offered by your telephone company. Contact them for instructions on accessing their voicemail system.
Feb 18, 2012 | Philips Lands Phones
Pls reg h-s philips cd 150problem
Hi, there,
I just have the same problem here in Taiwan. Now it's solved.
First, make sure phone line of your cordless phone is connected. Then, get to the advanced settings and key in default pin number (mine here is 0000), but don't press OK here. At the same time, push the "radial sign" in the center of CD 150 bracket for 3 seconds so it can deliver signals. Meanwhile, press OK button on the phone and if it's working, you will see
"waiting" and not long after that, no more PLS REG H/S.
Hope it's helping :)
also see :http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?mode=search&session=20110103075755_59.112.120.112&scy=TW&ctn=CD1501B%2F96&ds=CD1501B%2F96&slg=ENG&qslg=on&searchtext=registration&submit=Search
junana4van@gmail.com
May 09, 2010 | Philips Lands Phones
How do you turn the ringer on the cd440 model?
The ringer on the Philips CD4402B/37 CAN be turned off by holding down the # key on the dial pad for about 3 seconds (see CD 440 Manual, page 8, Item "I"). And a little "canceled note" icon appears in the screen. To turn the ringer ON when it is off, do the same!
Oct 05, 2009 | Philips CD4401B/37 Phone
Blinking message light
If you have message bank ie, message service for a VOIP then the signal will continue to detect if there is a message or not..I have turned mine off entirely..i wasnt using it much and the message continually was annoying..if tech support cant help..and they usually wont for your phone service..you will need to find the IP address (if using VOIP) for the phone, log in to that, go to advanced admin setting...passwords are usually admin/admin and somewhere under supplementary services you may see WMI or VWMI serv or something to that effect -i can only go by what i have seen on my screen - others may be different...and i have selected them both to NO...but also check with ur line provider that msg bank/voicemail is turned off..and if these are selected to NO then the message flashing will disappear!
Aug 06, 2009 | Philips CD4401B/37 Phone
Philips phones
Moved from Texas (CST) to Florida (EST). Brought my vonage equip. with me and kept my TX phone number. Just bought a new Philips CD440 phone. I set the date and clock to correct time. When I receive a call, my phone then reverts back to CST (loses an hour). I have checked all my Vonage settings; they show me as having EST and my new FL address. I can't figure out what is making the Philips phone think it is in CST. This is spooky.
Sep 03, 2008 | Lands Phones
What's the button on the base to register a handset?
hello Stephwen
On a CD440 base you should see at least a single button wich serves to call the cell phone, for the case when we don't remember where left the device, that's the button that you have to press during 3 seconds. On a CD445 base, you can see more buttons has the images showed on Philips pages... the button as a nice sign on it: it as a point with some curve barsto the rigth side as meaning "echo" or "sound"...
Complements
Jan 19, 2008 | Uniden Cordless Phone
Trying to download driver for philips skype/land line phone
Click on the following link
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=AU&slg=ENG&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=DUAL_PHONES_SU&grp=PHONES_GR&session=20080710232058_61.8.9.134&ctn=VOIP3211S/79&mid=Link_Software&hlt=Link_Software
Click download for the Vista Drivers. Download the driver to your desktop open the file to install the drivers. Reboot the computer
Plug the VoIP321 back into the computer.
Then on Skype go to Tools then Options.
Click on Advance and manage other programs access to Skype choose allow for the voip321.
Jan 13, 2008 | Computers & Internet
Lands Phones Logo
133 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
