Paper jam i recived a fax and it comes up that i have a paper jam after about 2 hours of searching for the paper jammed in there i couldn't find any anywhere
Machine is telling me to remove jammed paper and press stop/cancel.
I've tried this many times and there is definately nothing jammed.
Tried turning machine off and when I turn it back on the paper feeds
completely through before the machine tells me yet again that there
is a paper jam Machine is telling me to remove jammed paper and press stop/cancel.
is a paper jam
You can't post conmments that contain an email address.
Open the front cover and look at the white roller.
Is there anything jamming that? Like, say, a broken clip that's meant to hold the front cover in place as I just found happened to our fax machine.
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
to clear document jam: 1 Open the front panel. 2 Carefully remove the jammed document. 3 Close the front panel firmly until it clicks into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press Cancel appears in the message.
if the paper is jammed in the printing area 1 Remove the jammed paper by pulling it out smoothly in the direction of the arrow as shown. If the paper tears when it is being removed check to ensure that no small pieces have been left inside the machine. 2 Press Cancel. 3 If this was a fax, reprint the fax. For more information, see reprinting faxes on page 29.
if the paper is jammed in the paper feed area 1 Remove the jammed paper as shown. If the paper tears when it is being removed check to ensure that no small pieces have been left inside the machine. 2 Reload new paper with the print side facing toward you. 3 Press Cancel when finished.
Jams in the Document Tray When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD. When CHECK 5100 is displayed 1 Check if any paper is jammed. If jammed, make sure to take out all the jammed paper. 2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF]. Jams in the Multi-Purpose Tray If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD. 1 Gently pull any jammed paper out of the fax as shown, then press [Stop]. Pull it gently in either direction. If you cannot pull the paper out, continue with the steps below. 2 Open the Printer Cover. 3 Gently remove the jammed paper inside the fax. 4 Press [Stop]. The fax returns to standby mode.
The course of the problem could well be when you pulled the paper the wrong way out ot clear the jam. Open the machine and have a close look at the unerside of the flap. There should be a micro switch, which could well be desloged.
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
There are a few sensors in the paper path which can easilt dislodged when pulling paper to rapidly from unit. Check all sensor flags and make sure they are moving freely.
is a paper jam
