Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer Model# 11024642300
My washer will fill up with water, but will not start the cycle
  • 36 Answers
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Posted on Dec 16, 2008
Kenmore washer mod.11024642300 washer over flows
If it overflows while filling, the level sensor may have failed.
Feb 01, 2018 | Kenmore Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
684 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
