Question about Avanquest Driver Genius for PC (018059015555)
DOWNLOAD WHEN I INSTALLED DRIVER GENIUS FROM WEB AND CD JUST WHEN DOWNLOAD IS COMPLETED IGET AND ERROR 2003 OFFICE PROMPT ERROR 1706 SETUP CANNOT FIND THE REQUIRED FILES.CHECK YOUR CONNECTION TO THE NETWORK.FOR OTHER POTENTIAL SOLUTIONS TO THIS PROBLEM SEE c:\PROGRAM FILES MICROSOFT OFFICE\OFFICE 11\1033\SETUP.CHM I"M RUNNING WINDOWS XP
  • 11 more comments
  • kpohl Dec 16, 2008
    DOES THAT MEAN I NEED AND UPGRADE MISSING FILES IN OPERATING SYSTEM..SO SOFTWARE CAN DOWNLOAD..
    WHICH ALTERNATIVE NETWORK ADMINISTRATIVE INSTALLATION DO I USE/USE/CREATE/OR USE CD-ROM FOR THE OFFICE SOURCE LOCATION
    WHAT UPGRADE WILL I NEED FOR OPERATING SYSTEM BE SUSPIFIC...NOT REAL COMPUTER SAVVY..DO I HAVE TO UNINSTALL BEFORE THIS THEN REINSTALL...DO I NEED NEWER VERSION OF OFFICE?? OR DO I GO BY MICROSOFT HELP AND SUPPORT...
    i couldn't find www.tech-archive.net in the web..how else to update 2003 office
    YES RESTARTED SAME THING HAPPENS..
    TRIED REINSTALL AND PROMPT THIS THE FEATURE YOU ARE TRYING TO USE IS ON A CD-ROM OR OTHER REMOWABLE DISK THAT IS NOT AVAILABLE.INSERT MICROSOFT OFFICE SMALL BUSINESS 2003 DISK AND CLICK OK///DON"T HAVE 2003 MOSB DISK..NEXT PROMPT SAYS THE PATH'MICROSOFT OFFICE SMALL BUSINESS 2003 CANNOT BE FOUND VERIFY THAT YOU HAVE ACCESSS TO THIS LOCATION AND TRY AGAIN,OR TRY TO FIND THE INSTALLATION PACKAGE'STDP11N.MSI' IN A FOLDER FROM WHICH YOU CAN INSTALL THE PRODUCT MICROSOFT OFFICE SMALL BUSINESS EDITION 2003.HOW TO SOLVE THIS???
    I DON"T HAVE MICROSOFT OFFICE SMALL BUSINESS CD...HAVE OFFICE 2003 CAME WITH COMPUTER BUT PROMPTS FOR INSTALL DISK 2003 MICROSOFT SMALL BUSINESS..GOES THROUGH SAME STEPS BEFORE THEN THE 1706 ERROR.
    HOW DO YOU UNINSTALL 2003 OFFICE IF IT CAME WITH COMPUTER AND HOW DO YOU REINSTALL...WHICH CD CAME WITH COMPUTER..IS THIS 2003 MICROSOFT OFFICE SMALL BUSINESS IS ON ONE OF THEM..
  • kpohl Dec 29, 2008
    I HAVE WINDOWS XP SERVICE PACK 3..TRIED TO INSTALL WINDOWS INSTALLER FOR NT4.0 AND WINDOWS 2000 GOT ERROR OS OR OS VERSION FOR APPLICATION...SECOND METHOD DON'T KNOW HOW TO TO RUN IN ADD AND REMOVE PROGRAMS...
    I ONLY HAVE ONE CD-DRIVE...
    KPOHL@EMBARQMAIL.COM
  • kpohl Jan 06, 2009
    driver genius started working after update from server...should i reinstall or just let it go updateed drivers already...
    disappointed with installation took alot time wouldn't got it to download if it weren"t updated by server...and asking for help...
    Sergeant:
    Champion:
  • 304 Answers
This problem can occur if all the following conditions are true:
  • You originally installed Office from a network administrative installation.
  • The network administrative installation is no longer available to you.
  • You are trying to use an Office CD-ROM when you are prompted by the Windows Installer for an Office source location.
  • You click Cancel when you are prompted to insert the CD.
Because the files in an administrative installation are uncompressed, and the files on an Office CD-ROM are compressed, the Windows Installer cannot resolve the differences between the two source types.
Posted on Dec 16, 2008
  • 4 more comments
  • Elizabeth Krijt
    Elizabeth Krijt Dec 16, 2008
    go HERE under Microsoft Article.
  • Elizabeth Krijt
    The resolution to this problem depends on whether you can
    obtain access to a network administrative installation. Use the following
    methods, as appropriate to your situation.
    JUST go HERE under Microsoft Article.
  • Elizabeth Krijt
    1. Close all of the error messages described in the "Symptoms"
      section of this article.
    2. Leave the correct Microsoft Office 2000 CD in your
      computer's CD-ROM or DVD-ROM drive.
    3. Start Microsoft Office 2000 Setup either by attempting to
      use the "install on first use" component that you previously attempted to use,
      or by running Microsoft Office 2000 Setup from the Add/Remove Programs icon in Control Panel. Or, attempt to use the clip art that you
      previously attempted to use.
  • Elizabeth Krijt
    better to uninstall first the application.
  • Elizabeth Krijt
    this only means that the file was missing or corrupted
    btw.. what OS youre using?
  • Elizabeth Krijt
    Sergeant:
  • 237 Answers
4.17 Prompting driver file is damaged when opening it.
Please make sure that your drivers have been downloaded completely. You can click 'Tools' icon then choose 'Drivers download manager' to check download progress. The completely downloading drivers will be marked a 'green check' in Drivers Download Manager. If not please choose the unfinished driver and press 'download' button to continue.
var googleSearchIframeName = 'googleSearchUnitIframe'; var googleSearchFrameWidth = 700; var googleSearchFrameborder = 0 ; var googleSearchDomain = 'www.google.com';
If this does not work, go to these emails for support:
support@driver_soft.com
webmaster@driver_soft.com
Posted on Jan 06, 2009
    Master:
  • 413 Answers
Use an Alternative Network Administrative Installation loadTOCNode(2, 'resolution'); If the original administrative installation from which you installed Office is not available, you can use a different administrative installation for the Office source file location. To do this, follow these steps:
  1. Click Start and then click Run.
  2. In the Open box, type a command line similar to the following, and then click OK new network path\Setup.exe /fvm package name.msiwhere new network path is the full path to the alternative network administrative installation, and package name is the name of the Windows Installer .msi package on the root of this administrative installation (for example, Proplus.msi).
  3. Click OK when the update is finished.
Note After you follow these steps, the Windows Installer uses this new server location whenever it needs to reinstall, repair, or add a feature to your Office installation.
This page should help you if the previous didn't
Posted on Dec 29, 2008
  • 151 Answers
  • 177 Answers
I'd suggest un-installing and re-installing a free program like OpenOffice from JAVA.
It is not only free but is a lot more Effective and faster than Microsoft Office.
    Genius:
  • 1,605 Answers
Give me your e-mail address.
I will send you the file.
  • 340 Answers
Hi there and welcome to FixYa
  • When Microsoft Office 2003 Setup runs, the incorrect CD is in your computer's CD-ROM or DVD-ROM drive. For example, if you are running Microsoft Office 2003 CD1 Setup, CD2 is in your drive.
  • When you are prompted to insert the correct CD, you remove the incorrect CD; insert the correct CD, and then click OK.
  • regards
    Teis
      Mentor:
      An expert who has written 3 tips or uploaded 2 video tips.
    • 163 Answers
    Method 1 loadTOCNode(2, 'resolution'); Obtain the latest version of the Windows Installer, version 2.0. To download the latest version, browse to the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=4B6140F9-2D36-4977-8FA1-6F8A0F5DCA8F
    Method 2 loadTOCNode(2, 'resolution');
    1. Close all of the error messages described in the "Symptoms" section of this article.
    2. Leave the correct Microsoft Office XP CD-ROM in your computer's CD-ROM drive or DVD-ROM drive.
    3. Start Microsoft Office XP Setup by doing one of the following:
      • Use the "install on first use" component that you previously attempted to use.
      • Run Microsoft Office XP Setup from the Add/Remove Programs icon in Control Panel.
      • Attempt to use the clip art that you previously attempted to use.
    If the correct CD-ROM is in the CD-ROM drive or DVD-ROM drive when the Windows Installer starts running,
    • Cloudbooks Dec 30, 2008
      hi
      I guess the problem is with your operating system as there may be some errors while you were installing the operation system
      please do clean format of c:\ drive and install the drivers and office 2003. it will slove your problem
      Sergeant:
      Champion:
    • 435 Answers
    Hi, while re-installing, normal uninstall is not enough. After you uninstall, some files would be left behind. Please delete them manually. They should be inside the folders where you installed (probably in C:\ Program Files\   folder).
    Then try installing the fresh copy of the both softwares. and for any updates on microsoft products, get it from www.microsoft.com or  www.msfn.org/
    • 112 Answers
    HELLO SIR,
    THIS THE VERY SIMPLE TO AVID FROM THIS ERROR,
    UNINSTALL YOUR OFFICE AND THEN RE INSTALL YOUR FRESH COPY TO IN YOUR SYSTEM
    ERROR WILL BE REMOVE FROM YOUR SYSTEM
    GOOD LUCK,
    • MOHSIN AMIN
      MOHSIN AMIN Dec 16, 2008
      HELLO SIR
      I HOPE I HAVE TO SOLVE YOR PROBLEM
      IF YES
      THEN GOOD
      IF NOT TEL I ADVISE MORE FOR SOLVE YOUR PROBLEM
    • 124 Answers
    That error generally signifies that a part of office is trying to install, but the installation of Office you have was a network installation, and thus it's looking for the network install path.
    To remedy this, you'd have to have an office cd (same version of course) and when it asks for the location, point it to the file it's looking for on the cd.  Otherwise, I'd suggest uninstalling Office and reinstalling from the cd.
    • Jason Edinger Dec 16, 2008
      Uninstall:
      Click Start button, Control Panel, Add/Remove Programs.
      Scroll to Microsoft Office. Click it, Remove.
      Reinstall:
      Put cd in drive, follow directions on CD.
    • 1,879 Answers
    "ERROR 2003 OFFICE PROMPT ERROR 1706 SETUP CANNOT FIND THE REQUIRED FILES"
    forget about that OPERATING SYSTEM STUFF
    trash OFFICE & do a FULL REINSTALL
    then install DRIVER GENIUS
    • monk3ybidzness
      monk3ybidzness Dec 16, 2008
      you need the MOSB disk to resolve this
    • monk3ybidzness
      how/who installed MOSB in your computer in the first place ?
      if you don't have the disk, you have to buy one.
    • 679 Answers
    Run a windows update from your start menu. It should tell you if you need an update to the program, if so it will download the necessary files. If the program is no longer supported, you can find the solution in the microsoft solutions web site, which you will be on if the update dosen't work.
    • George Bill
      George Bill Dec 16, 2008
      Also i should have mentioned you ned to direct it to the files if you are going to do it the way you started. Something like C, program files, microsoft office, office. then the specific program, and then the folder that has the driver in it, this is why you are better off letting the microsoft update do this for you, as long as it's a registered copy, it should be supported.,Peace
      Genius:
    • 1,199 Answers
    Did you try restarting your computer!
      President:
    • 1,952 Answers
    Re: Microsoft Office 2000 SR-1 Premium -- Error 1706, Bob Buckland ? ...... Install Office 2003 Upgrade without Office 97 cd?, Dan. Re: Install Office 2003 ...
    www.tech-archive.net/Archive/Office/microsoft.public.office.misc/2005-05/ - 367k -
      President:
    • 2,110 Answers
    1. Insert your Office CD-ROM.
    2. Click Start, and then click Run.
    3. In the Open box, type a command line similar to the following, and then click OK CD-ROM drive:\Setup /a where CD-ROM is the drive letter of your CD-ROM drive.
    4. In the Administrative Installation dialog box, specify the location on your hard disk for the Office administrative installation, and then type your Product Key (CD key). Click Next.
    5. Click OK when the installation is finished.
    6. Follow the steps listed in the "Use an Alternative Network Administrative Installation" section to change the Office source file location to the administrative installation on your local hard disk.
    • Sibananda Jena
      Sibananda Jena Dec 16, 2008
      If this not help then try this...
      1. Quit all Office programs.
      2. Double-click the Add/Remove Programs Control Panel.
      3. Double-click the entry for the Microsoft Office 2003 or
        Microsoft Office XP product that is installed.
      4. In the Maintenance Mode Options dialog box, select Uninstall Office, and then click Next.
      5. Click Yes to confirm the removal of Office.
      6. Click OK when the removal is finished.
      7. Insert your Office 2003 or Office XP CD-ROM.
      8. Follow the Setup dialog boxes to install Office from
        CD-ROM.
      Genius:
    • 1,011 Answers
    Sir,
    Click this link to solve the problem
    http://error1706.windowsreinstall.com/
    thanks
    good luck
    • 1 more comment
    • Asfiya Ahamed
      Asfiya Ahamed Dec 16, 2008
      u just to overwrite(don't uninstall just install again) your ms-office it will solve ur problem
    • Asfiya Ahamed
      Use Your CD
    • Asfiya Ahamed
      do some steps........
      1) open my computer-> C:/>Program files> Microsoft Office. Cut this folder and paste with other drive. Go to microsoft website download the trial version of Microsoft Office 2007.
      2) After download install the office 2007 at C: drive. Run it. It solved u sucessful solved the problem. If not solved, undo all the things.
      3) i.e Cut and paste the folder into c:/> (that office 2003 folder, before u cut and paste with different drive)
      after click the below click and update the office 2003. it may be solved. if it not worked let me know.
      thanks
      good luck
      http://office.microsoft.com/en-us/downlo...
      Sergeant:
      Novelist:
    • 327 Answers
    Some of the files r missing in your operating system that r blocking the software to get loaded.
    • classyexpert Dec 16, 2008
      yes.u r correct u will need to either upgrade your software or format the current operating system and reload it again so that the missing files get loaded again if deleted by mistake.
    A file SKU012.cab not found
    To resolve this error permanently, you must repair the Office 2003 installation. This resolution is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ (http://support.microsoft.com/contactus/) Repair the Office 2003 installation To repair the Office 2003 installation, use the Local Installation Source Tool. You can download the Local Installation Source Tool from the following Microsoft Office 2003 Resource Kit Web site: http://www.microsoft.com/downloads/details.aspx?FamilyId=10FA7AA3-695B-42C3-9045-B812BA0FED3E&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyId=10FA7AA3-695B-42C3-9045-B812BA0FED3E&displaylang=en) After you have downloaded the tool, double-click the LISTool.exe program file on your hard disk to start the Setup program. Follow the instructions on the screen to complete the process.
    The Local Installation Source Tool is a wizard that helps manage your Local Installation Source (LIS) on computers that are running Microsoft Office 2003. The LIS is the group of installation files that Setup copies to a hidden folder on your computer when you install Office 2003 from a CD or from a compressed CD image on a network. The LIS Tool lets you enable or disable the LIS, and to move the MSOCache folder to a new volume.
    Note If these methods do not work, the files in the \MSOCache\All Users\download code folder may not match the files on the CD that you provided. Make sure that the CD that you inserted matches the product that is being requested. For example, the product that is already installed on the computer may be Microsoft Office Professional Edition 2003. However, the CD may contain files for Microsoft Office Professional Enterprise Edition 2003. If this is the case, remove the Microsoft Office product, and then install the product again from the available CD.
    Mar 14, 2013 | Microsoft Office Standard Edition 2003 for...
    File sku012.cab not found
    Mar 14, 2013 | Microsoft Office Computers & Internet
    How to instal windows software 2003
    very vague question, but typically , locate 2003 cd. insert disk , follow on screen prompts. if autoload is not working. with the disk inserted, browse the CD using "my computer "..... CD or DVD drive.... locate setup.exe icon (typically blue computer icon) double click to launch the installer. ....follow onscreen prompts. Please note office 2003 is getting old now., be sure to google "microsoft compatability pack" download and install that too. hope that helps Cheers
    Aug 26, 2010 | Microsoft Office Outlook 2003 for PC
    PRO11.MSI installation package could not be found while using Microsoft Office Proseffional Edition 2003 creating an error # 1706
    The install disk is corrupted and you need a new one. Either borrow the disk from a friend or download a new installer from here
    http://www.brothersoft.com/microsoft-office-2003-169273.html
     All you need to have is your personal key.
    Aug 08, 2010 | Computers & Internet
    Get error sku112.cab. when trying to install office home and student2007
    Feb 14, 2010 | Microsoft Office Home and Student 2007...
    XP C-drive onto new mobo/cpu/ram gives 1706 errors on start-up
    Did you undertake a "repair" of the XP installation..? You should repair the existing installation using your original install disk But don't use the Repair console option, Go past this option until the install program tells you that it has detected an existing installation and would you like to either repair this installation or re-install from scratch.. Choose the repair option. Once this has completed, you should then install the mainboard drivers and then, go to Windows update and install ALL the required updates. This method ensures that the old mainboard drivers are removed and the new ones, including updates are installed. If this fails for whatever reason, you may have no choice but to undertake a full re-installation of XP including a format of the drive (sorry).. Then, once you have done this, you will need to re-install MS Office again as the repair of XP will overwrite some of the data and DLL files belonging to MS Office..
    Jan 16, 2010 | ASUS A8N-VM CSM (00610839133826)...
    The microsoft office 2003 installation
    First do this
    To resolve this behavior, start the Setup program for Office. To do this, follow these steps:
    1. Insert the Microsoft Office 2003 CD in your CD drive or DVD drive.
    2. If the Setup program does not start automatically, locate the Setup.exe file on the CD, and then double-click the file to start Setup.
    3. After the Setup window appears, cancel Setup, and then respond to the prompts to exit Setup.
    Note You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
    If it doesn't help follow these steps.
    go to add/remove programs via control panel
    the go to office 2003
    select "change".
    Select repair
    You will be asked for the installation CD. Please insert it before start this procedure.
    Then do a repair and follow the instructions
    Thanks
    If this helps you, please rat the answer
    Good Luck
    Jun 24, 2009 | Microsoft Office Professional 2007 Full...
    Microsoft office
    When you try to start a Microsoft Office 2007 or Microsoft Office 2003 program, you may receive the following error message or an error message that is similar to the following:
    Error 25090. Office Setup encountered a problem with the Office Source Engine, system error: -2147023836. Please open SETUP.CHM and look for "Office Source Engine" for information on how to resolve this problem.
    CAUSE
    This behavior occurs when the following conditions are true:
    * Two people installed Office on the same computer.
    * Both installations were completed by using the AllUsers="" parameter to set the installation for the installing user account only.
    * When both people were prompted to remove files that were copied locally at the end of Setup, both people did not remove the files.
    * One of the two people removed Office.
    RESOLUTION
    Note: You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
    Sep 05, 2008 | Microsoft Office Outlook 2003 for PC
    Web cam genius
    Genius GF112 Model:Video CAM GF112 S/N 129866801958 made in china 12041366100-B
    I lost de cd for this products, I like to have imformation about how to download a new software or get the nessesary driver for. please would you help me on it? If there is please send mi the information tu this mail address gabrielena@hotmail.com
    Nov 16, 2007 | Genius VD3000022 Webcam
    Avanquest Driver Genius for PC (018059015555) Logo
    421 people viewed this question
    Top Avanquest Computers & Internet Experts
    Alun Cox
    Chris Larocque
    Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
