I was told when I installed my wireless N-Router I would get the distance I need. Far better than the G I was using. Am getting two bars on the rating scale at about 50 feet. What can I do to enhance the distance to at least 75 feet ?
  • 69 Answers
It depends what kind of router/dsl u have and usb stick or pci card , if u use from the both brands than its easy to install, first the modem/router you should configure it good in the gateway (192.168.1.1) or something like that u should look in the manuel, than install the software for the stick or pci card than install, than it should work fine
Posted on Dec 16, 2008
Wi-fi distance of beetel 450tc1 adsl2+router
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the other sideof the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Mar 28, 2012 | NetGear WGR614 Wireless Router
I recently installed a Belkin N+wireless router which connects to several other devices in the house but I can't get the Sylvania Blu-ray to connect. The distance from the router is not very far away. I...
What type of wireless security are you using? Some dumb devices (non-computer/Wii/Nintendo DS) cannot connect to routers using certain security methods. Try temporarily turning off your wireless security from the router or switching from WPA to WEP or vice versa. This should help you narrow down the problem.
Also, make sure your router is broadcasting the SSID, some devices don't handle unbroadcast SSIDs very well.
Feb 28, 2011 | Televison & Video
My msi iu100 is no longer able to use our wireless router at home. all the other computers in the home are able to access wireless fine. The msi worked with wireless router at another location. ???
How far is the MSI from the Wi-Fi router? Maybe the distance or some walls between your MSI and the router is the problem. If it is possible check with another computer at the position that MSI can not connect to Wi-Fi.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 17, 2010 | Computers & Internet
WEAK signal :-( How do I extend the distance or wireless reach.
Either look into getting bigger (higher gain) antennas for your router, or get bigger/stronger antennas for your PC's.
Other than repositioning the existing antennas or putting the router higher up in the air, there isn't much you can do.
May 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
Low wireless signal strengh
You have two options...
1. Try bringing the laptop closer to the router.
2. Buy a wireless N Router to better distance.
Dec 22, 2008 | Gateway Computers & Internet
Problem with mac seeing this wireless router
hi,
please log onto router user interface by typing 192.168.1.1 in address bar>>
check whether ssid broadcast is enabled or not-it should be enabled>>
change ssid,and security key (wep or wpa) if any.>>
power cycle or restart router>>\
on mac os-click apple menu---click network preferences--network utility--change the show parameter as airport>>it will scan and show the network>>click on ok or apply>>
ps:make sure wifi-switch is turned on and distance is not too far.
thsnk you.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
Distance from TX to RX possible too great
There are a couple more questions
  1. Is it a removable antenna on the wireless router e.g. 5db or 7db gain. you could just get better antennas to increase signal strength for distance.
  2. E-bay has a linear antenna you assemble with a usb wireless network adapter attached.
Mar 31, 2008 | D-Link AirPlus DI-524 Wireless Router
Call of duty 4 online
this is common problem in online gaming.... it is always recommended to have your console hardwired to the router.....your is either too far away, another wireless device is affecting it (cordless phone close to the wireless router can cause interference), your wireless net work is not secured enabling any one close to your house to get on your network which inturn will slow you down, or you may need to get range boost anntanas depending on the router you have and that you can do that type of upgrade...or you mat need a super g or n router for greater distance.
Feb 02, 2008 | Sony Playstation 3 (PS3) Console
Wont install
I have only tried this on Windows XP. If you can connect to the web using a hard line you can get this running. Make sure you have internet. Then plug the wireless adapter into the usb port and when windows ask if it can search the internet say yes. That will install a driver for the wusb54gc. Then windows will manage the device. Linksys only has the option to download the installer as opposed to just the driver. What a pain when the installer doesn't work.
Nov 10, 2007 | Linksys Wireless-G WUSB54GC (WUSB54GC-BP)
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
