Question about Electrolux Vacuums
Burning motor - Electrolux Vacuums
  • 125 Answers
Are you ready for this.
you bought a eurika vacuum with the lux logo
if the motor stinks, it is shotand needs to be replaced
a genaric motor will run around 40 bucks, as opposed to the eurika for over 100
Posted on Dec 16, 2008
D25 ball motor screaming noise burning smell and smoke coming from ball. Extended warranty expired recently!
The motor has seized and burned up. Its going to need professional repair as those motors are electrically controlled and not normal 120V motors.
Oct 16, 2016 | Dyson Dc 25 Animal
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
The dyson smelt of burning then stopped sudenly
Hi the burning smell is from the Motor. Your Motor has burnt out. You will need it replaced.
A new motor will cost around £40
If you would like us to advise you on how to swap the motors over then please order the motor and come back to us.
Thanks you
Aug 19, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum is making a burning smell from the motor/fan.
Actually the screws to access the motor on Kenmore canisters are located underneath of the foot pedal that retracts the cord reel, and there's usually also two screws that underneath of the tool lid arms.
You may access the screws underneath of the cord reel by prying the foot pedal off of the vacuum. Simply put a flat head screw driver in between where the foot pedal and the vacuum cleaner meet on the top of the machine, and pry upwards with the screw driver. Once you remove the pedal you'll see the screws and have direct access to the vacuums motor.
If you are trying to access the power nozzle motor, here's a detailed step by step instruction tutorial that will walk you right through it.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
When a vacuum cleaner smells like something is burning, it can only really be one of two things. Either the rubber belt inside of the power nozzle is burning, or the motor is burning. If it's the belt that's burning, it will be a burning rubber type of smell, but if it's the electrical motor, it will be more of an electrical smell.
If you have any further quesitons, please feel free to reply using the clarification request tool here on Fixya. I'm always more then happy to answer any follow up questions.
If this was helpful, please rate my repair by clicking the thumbs up icons in the top right hand corner of this repair.
Thank you,
Chris J.
GoVacuum.com
Apr 11, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Burning odor and burning at thewhite line
It's time for a new motor, although it might not be worth it as your probably going to spend roughly 60 dollars for it and new ones are a little over a hundred
Aug 29, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Motor is getting loud and smells like is burning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=832949
Generic problem for all Vacuums
Posted by lchill on July 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not sure what type of vacuum, make or model # it is but if your motor is getting loud and it smells like it is burning, it could be 2 things, either you have a broken fan blade or your motor is on it’s last legs and is burning up and would be in need of a new fan and motor replacement. Please feel free t contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 25, 2008 | Kenmore Progressive Bagless Upright with...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
108 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
