Question about Estate Dryers
Estate Dryer takes too long to dry load
Vent pipe is ok. Unit seems to have sufficient heat.
  • 585 Answers
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Posted on Dec 17, 2008
Dryer takes a long time to dry?
disconnect the vent pipe behind dryer,dry a load and if it after an hour clothes are dry then you may have a house venting blockage. also check all seals(door,drum,blower hosing).
Feb 14, 2011 | Estate TEDX640JQ Electric Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Had the same problem a while back and it turned out to be a plugged vent pipe
Mar 22, 2010 | Estate TEDS740JQ Electric Dryer
Wont dry clothes, i can turn it on and wait a second then open door and heat appears to be onbut it seems to take hours and hours to dry a load
You may have a blocked vent.
Remove the connecting vent from the rear of the dryer.
Run a load of laundry.
Use timed dry at 50 minutes if possible.
If it dries correctly clean and repair the exhaust vent.
Dec 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
Dryer taking too long to dry
If you can get the dryer outside, blow it out from the bottom with compressed air (using an air compressor or even a leaf blower). make sure the vent is clear and has no lint buildup. make sure the burner unit is also lint/dust free. If it is still heating, that is good news, and it is most likely a "breathing" issue. it also could be an issue with your gas pressure, however that is very unlikely. Best wishes in this project.
Oct 22, 2009 | Kenmore 73952 Gas Dryer
Dryer will not dry heat but low air flow
check the blower fan on motor shaft,then all vent piping then the vent hose to the outside for a restriction or lint plug
Oct 05, 2009 | Estate EGD4300TQ Gas Dryer
I have model # eed4300tq0 it takes 3 times longer to dry than it use to. it use to dry in one cycle on high heat,now i have to use high heat 3 times to get completely dry. dryer is only 1 and a half years...
Blocked vent hose . Disconnect the hose from the dryer and dry a load . If dryes ok , check the vent hose and vent . Make sure there is good air blowing out the back .
Aug 08, 2009 | Estate TGDS840JQ Gas Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryers Logo
76 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
