Question about Intel D845GVSR Motherboard
Somehow a few of my system files have been deleted and I have no virtual memory left,....Can I retrieve them without the Windows installation disk or using system restore? How?
    President:
  • 2,351 Answers
You can try this Microsoft link: http://support.microsoft.com/kb/304449
Follow the instructions.
Mike
Posted on Dec 17, 2008
System is very slow both on WIndows and Linux platforms
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 18, 2013 | Computers & Internet
Hi MY laptop is running very slow
For the better performance delete cookies,temp files from the computer.
Uninstall all the unwanted softwares from the computer.
Run disk clean up
  1. Open Disk Cleanup by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking Disk Cleanup.
  2. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. If the Disk Cleanup: Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
  4. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
  5. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer.
.To run disk defragmentation.
1. Open the Start Menu. A) In the white line (Start Search) area, type dfrgui and press Enter.
OR
B) Click on All Programs, Accessories, System Tools, and then on Disk Defragmenter.
Increase the virtual memory of the computer.
How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
This will improve the performance of the computer.
Thanks.
Aug 20, 2010 | Computers & Internet
Slow
Hi Whose,
Me again :-)
Yes m8, there is something you can do.
Perform the steps given below to increase your system performance.
Uninstall all unwanted software:
To uninstall software
Click on Start
à Settings à Control Panel à Add/Remove Programs
Select the software (one at the time) from the list and click on the Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Dec 11, 2008 | HP Compaq nx6110 PC Laptop
Computer is slowing down
Hi Big Bad Bob, and welcome to FixYa,
you computer is "dirty", clean, and feel the difference:
Click on Start
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
regards
Yeis the Wiz -> vote :-)
Dec 06, 2008 | Computers & Internet
My C:\drive is full and i have removed files to make space but it stil says there is not enough space on drive. What can i do?
Copy this text into a word document, print it and have it next to you when you ferform this:
Perform the steps given below to increase you system performance and clear space.
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 30, 2008 | Acer Computers & Internet
My computer needs a clean out.
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Erase unnecessary files in the windows temporary folder.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 29, 2008 | Computers & Internet
Gateway mx6930 laptop freezes up every 10 minutes - keyboard and mouse become inoperable
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Low virtual memory what shoul i do?
Start-settings-control panel-system
Click on the Advanced tab
Click settings under performance
Click on Advanced
Hit "Change" at the bottom
From here, it's usually set to "system managed size", but if not, set it to that, or manually set the size to 1.5 times the amount of system RAM you have. (your choice)
If there is no problem there, then the disk with the virtual memory (page file) is probably full and has no space left.
If that's the case, use a different disk for the page file. (a few clicks on that same page)
Aug 24, 2008 | Microsoft Windows XP Professional With...
I've Run Out Of Memory Without Adding Anything New To The System
When you deleted files, what you are freeing is hard disk space and not memory.
What I suspect is that at startup, your PC loads a number of programs that may or may not be essential for the system operation but nonetheless uses memory. This greatly reduces available/free memory and when you really want to run an application, the PC has no more memory to spare.
The easiest way I could think of to free up more memory is to streamline your startup applications. This could be done by running your System Configuration Utility (Start/Run, type "msconfig" less the quotes, Startup tab).Try to Disable All or uncheck all entries (except perhaps your antivirus and any application that you feel may be essential).
Additionally, you can increase your virtual memory. This could be done in your System Properties/Advanced tab/Performance Settings button/Performance Options Advanced tab/Virtual Memory Change button and select Custom Size. Numbers should roughly be equal to twice your real memory (say onboard is 512, then virtual = 1024). You need to click on the Set button, OK,OK,OK and reboot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Dell Inspiron B130 Notebook
Intel D845GVSR Motherboard Logo
20 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
