Question about KitchenAid Architect Series KEBC278KSS Electric Double Oven
DOUBLE OVENS FROM KITCHENAID
OVENS ARE LESS THAN SIX MONTHS OLD. WHEN IN OPERATION AND AFTER PRE HEATING, A NOISE STARTS THAT SOUNDS LIKE A GRINDING NOISE. OR....IT STARTS WHEN I TURN THE OVEN OFF. IT HAS STARTED IN THE LAST THREE WEEKS.
  • liana747 Nov 24, 2008
    Same problem. What did you find out. Mine is out of warranty.
I had same problem on similar KitchenAid model (combo microwave/oven), and it was past warranty. The noise is the blower that is used to circulate air inside the unit. We ended up fixing it ourselves, took oven out of cabinet, removed the backing (tin), and found that the blower blade unit is fairly low quality. We took it apart and found that the "axel" that holds the blades on had slipped from the hole. We put it back in, and then crimped a piece of wire around the end to hold it in place. Since then (16 months ago) no further problems.
Posted on Mar 07, 2009
    Scholar:
  • 76 Answers
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Posted on Mar 22, 2007
Kems308sss05 starts heating to a preset temp, then stalls. Both broil/bake elements get hot, no spots or breaks. When I try to preheat again, the start temp is less than the # it stalled at.
Top 42 Complaints and Reviews about KitchenAid Wall Ovens
www.consumeraffairs.com > Homeowners > Ranges/Ovens/Stoves
Rating: 1.6 - ‎35 votes I missed 2-days of work, once for diagnosis and then another for them to ...KEMS308SSS05 - I purchased this product in Jan 2012. ... Ordered parts, two weeks later parts came and when the heating element was .... I used the self-cleaning unit in top and bottom and noticed in November the temperature took a long time to ...
Nov 08, 2015 | Ovens
Smoking near top heating element upon initial operation
Some oil of some kind must've been on the heating element. No worries.
Feb 17, 2015 | KitchenAid Kitchen Aid KEBS208SSS Double...
No heat from my Electrolux oven fan is running but oven light not working the oven is only six months old
Thank you for your inquiry, friend!
Based off the information you have provided your Electrolux oven is not heating properly. I would recommend performing a reset on your range which you can do by disconnecting power from it for ten minutes. If that does not help to correct your issue it could be a faulty element or control panel. I understand your range is only six months old typically the warranty for a range is one year. I would contact the manufacturer for proper resolution regarding a warranty. I hope this is helpful. -Matt
Oct 17, 2014 | Electrolux Ovens
Kitchenaid superba microwave not working smell
Junk it and buy new, do not run this anymore may catch fire.
Mar 01, 2014 | KitchenAid Architect Series KEMC308KSS...
The oven will not heat up, it will say start, I enter the temperature I would like it to heat up, it will say that on the display, I can hear some noise (sounds like a fan) but there is no heat. And the...
Good morning, the fan noise is probably the cooling fan in the control compartment. With an electric oven, it could be a resettable thermostat that tripped and needs to be reset. Or it could be a bad heating element. Display will display lot if it can't bring the oven temp up. Hope that helps.
Feb 09, 2018 | KitchenAid Architect Series KEBC208KSS...
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
KitchenAid Architect Series KEBC278KSS Electric Double Oven Logo
866 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
