Question about Whirlpool LGQ9858P Gas Dryer
Thumping noise Big thumping noises when dryer is on . Sounds like a sneaker is in the dryer
  • Anonymous Mar 26, 2014
    Big thumping noise.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sgs
Posted on Sep 30, 2010
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
The dryer works but makes a loud thumping noise model#GLEQ642AS2
All dryers have some type of roller system that supports the drum as it turns. It sounds like one of the rollers or roller bearings has worn and is making that thumping noise. If you have some basic skills and good general mechanical sense you could fix it yourself. Make sure the dryer is unplugged before you attempt anything.
Feb 25, 2011 | Frigidaire Dryers
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Makes a thumping noise when drum goes around, kinda like there was a sneaker in there. how do I open it up to check what the problem? Maybe belt starting to go bad?
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 12, 2010 | Frigidaire Electric Dryer
Unexplained dryer noise
I have this same problem, how do I get to the belt to check it out?
Mar 21, 2010 | Amana NED7200TW Electric Dryer
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Our Asko dryer (T720) has begun to make a heavy thumping noise, even if empty. (Sounds like a single wet & heavy object is in dryer)
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Aug 01, 2008 | Asko Dryers
Noisy drum
You may have a rear drum support issue. There are 2 rollers,(supports), 1 at 4 o'clock and 1 at 7 o'clock. If the bushing in the roller becomes elongated,(elliptical), it will give a thumping noise, as you describe.
Below is a link with exploded diagrams and parts help.
http://www.repairclinic.com/0100_14.asp
Please rate my answer on how helpful it was in resolving your issue.
Thank you,
Dave E. (Illeagle)
Jun 16, 2008 | Whirlpool Dryers
Help
thumping noise sounds like a flat spot on rollers, or front felt assy is falling off
Feb 21, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool LGQ9858P Gas Dryer Logo
800 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
