Question about Majestic MP3500CD CD Player
Majestic Mp3 Problems
My Majestic MP3500CD will not play my MP3 cd, it just says NO FILE and goes to tuner. The Cd works in my computer.
0 characters
1 Points
go to alpine website and you can pull up a manual from the archives and print it out. Umm as far as playing disks you just flip the face down and load a disk into it and it will play it . you will probably have to have an mp3 cord plugged into it to access the "auxillary" mode under the sources button. But other than that yea just hit the source button and it should switch between tuner cd and aux to play whatever you need it to play
Jan 31, 2010 | Alpine CDE-9852 CD Player
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Have you tried cleaning the unit with a "Laser Lens Cleaner?" one that uses fluid? Mp3 is a fickle format and your deck may be having issues reading it. Try running a cleaner thru it. Secondly, when you burn discs, make sure you finalize it by making it "compatable for all player types" Hope this helps
Jun 25, 2009 | Sony CDX-F7500 CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
My 1998 Jeep Cherokee cd player does not work, displays "error when cd inserted, the radio works fine, can it be repair?
it will read burnt cds, the only thing is that it will not play .mp3  format songs, if you can somehow change the format to something else it should work just fine. i had a friend who's car had the same problem and switching the file extension from .mp3 to something else like .mpeg or something else should work. the cd player in a 98 grand cherokee is older and does not have .mp3 play back on it so it cannot read .mp3 format files. that's the only reason it doesnot register. try different audi files out and it should work. give it a try. i hope that helps out some.
Dec 30, 2008 | Jeep AM/FM Cassette with CD Changer...
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
MP3 CD's
Sometime when put too many file in a cd then the scond half of the cd get corrupt. Try play that cd in another player see if it work. Certain unit could only read certain compressed size file too small and it would be view as corrupted.
Nov 12, 2007 | Alpine CDA-9856 CD Player
CDX-M8800 won't read CD-R discs
hi mate did you make the cd if so make the cd on slow speed it will work then max of 16x on you cd ok mate
Oct 19, 2007 | Sony CDX-M8800 CD Player
225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
Jul 31, 2007 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Kenwood KDC-2025 won't play CDs
source Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Majestic MP3500CD CD Player Logo
361 people viewed this question
Top Majestic Car Audio Receivers Experts
xxxxxx xxx
Are you a Majestic Car Audio Receiver Expert? Answer questions, earn points and help others
