Question about Kenmore 24032\24036 Top Load Washer
Washer over flows
My kenmore 80 series washer will not stop filling. The unit still works because I used the spin cycle to drain.
    Scholar:
  • 33 Answers
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Posted on Dec 16, 2008
    How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
    Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
    Aug 08, 2014 | Kenmore Washing Machines
    Kenmore Washer Series 80. The cycle stops before
    check to see if you have it set on drip dry
    Feb 06, 2010 | Kenmore Washing Machines
    Kenmore washer won't stop filling during initial wash cycle
    I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
    Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 Series washer wont spin or drain at end of cycle
    POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
    Apr 17, 2009 | Washing Machines
    Won't complete cycle, stops at rinse. and can't get hot water.
    Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
    the machine probably has a cold only final rinse so it won't work properly.
    Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
    you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
    Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 series washer stopped during unbalanced spin cycle
    lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
    Apr 29, 2008 | Kenmore 20172 Top Load Washer
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 24032\24036 Top Load Washer Logo
    109 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
