Question about GE Spacemaker JVM1640SJ Microwave Oven
Handle came off
GE Space maker( black) the handle came right OFF
from top and bottom.. NOW WHAT... do I do ..????
PLease H E L P ...
  • GE Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 17, 2008
I need a door handle for GE space maker microwave
You can usually find replacement parts by search the internet for:
Make Model replacement parts
Jan 07, 2017 | GE Microwave Ovens
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove inside door trim to replace handle on G.E. space maker mod#JVM1341BW002
Very carefully. You will need one to two flat head screwdrivers. There is a piece in the inner door that covers the screw holes. It snaps in. Once it is removed you should be able to see the screws to the back side of the handle. Just be careful removing inner trim because they are prone to break.
Nov 21, 2009 | GE Microwave Ovens
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
My Microwave is not lighting up. I have no power and the circuit is fine. it's a GE space maker 2.0 and it's only 2 years old.
THERE SHOULD BE SOME SCREWS ON THE BOTTOM SIDES OF THE MICRO REMOVE THESE SCREWS AND REMOVE THE TOP HOUSING YOU WILL SEE A FUSE SOME WHERE IN THERE CECK THIS FIRST
Aug 15, 2009 | Microwave Ovens
GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Instructions for replacing door handle on JVM1350BW02 Microwave
You may have to rotate and pull the handle once the top screw is removed.
Sep 04, 2008 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Broken handle
1) Have to remove the door first; top of the oven there are two screws closest to the door, take those out. and the door should lift out
2) flip the door on the table with the handle side down. starting on the handle side there are three clips (top, middle, and bottom) between the outside casing and inside trim. Using a thin screwdriver gently twist starting at either the top or bottom to pod the two casings apart. work your way around the door.
3) You should see one of the screws that hold the handle on (top) but the bottom screw is under the metal casing so you need to remove the screws around this casing as well to get the other handle screw off.
Once you start you will see it isn't as bad as this sounds. I bought the handle for $40.
It is a shame that this is so cheap and breaks off this easily. Surprisingly we have had ours for at least 6 years before the handle broke and we have 3 girls opening and closing this all the time so I guess I was one of the lucky ones.
Hope this helps and good luck
Nov 20, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
27 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
