Question about SVA-USA VR-20 20 in. HD-Ready LCD Television
Frozen buttons I changed the chanel on the tv by mistake, and now the tv is frozen on chanel 4. I tried unplugging and replugging, but as soon as I turn the TV on and it registers TV mode, the buttons lock and I cannot change the chanel, volume, or ever power it off. It there a way to solving this?
SOURCE: SVA HD4208 42INCH Plasma will not turn on.
I called the factory or the distributor or wholesaler (customer service) that comes out on the web and they told to just buy a new remote cuz tv just isn't recognizing the remote. Can this be true? If this is far from being true, where do I buy the boards and what are the chances that the boards are the real problem?
thanks once again.
Posted on Feb 12, 2008
0 characters
1 Points
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
Apr 02, 2014 | Samsung Flat Panel Televisions
LCD 32lg3000 frozen
Make a hard reset to this set, and try again. To make it a hard reset, unplug the power cord from wall socket, and re-plug it into after 10 minutes or so. This must make it a hard reset. In most cases, this must help.
Jul 18, 2012 | LG Flat Panel Televisions
How do i reset my lc26dv20 u back to factory so that my inputs will work
Just unplug,replug the tv back about an hour later.The tv now,it is resetting back to the factory setting.If ur tv still have the same problems,ur tv Tuner signal board itself is the causes and the problems,must be change the tv Tuner signal board it self,if u want the tv to be fix.
Apr 27, 2011 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
Is there a way to reset a westing house flat panel tv? It is frozen
call sears they charge $99 to come out free estimate. mine cost $300 to fix, get your estimate and go from there good luck
Dec 19, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I am getting an error telling me the smart card is inserted incorrectly even though it hasn't been taken out. volume and caption is frozen with no picture.
Unplug tv replug it an hour later.The tv now,will reset itself back to factory setting.Now,it should work.Not,the tv Tuner board is dead.That the board,where the in comming broscasting signal cable plug into it.Tries websites like, to buy a refurbish Tuner board for the replacement.
Sep 08, 2010 | Mintek DTV-265-D 26 in. LCD TV
My Samsung Le32r73bd TV has frozen so that I can only watch one channel. I have tried turning it off at the mains. Changing "source" and resetting the remote control but it has not fixed it. Any...
Unplug,replug ur cables,satalites,or telicoms boxes for about an hour or so.Replug these boxes back in let the software upgrade,the tv signal should be back to normal.Tries that,99% will solved this problems u have.
Mar 09, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sharp aquos digital tv won't turn on
Did you try buttons on the TV? Sometime it help to unplug it from the wall for a couple of minutes. Is there any flashing lights? If yes, what the sequence?
Dec 04, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ch 9 picture froizen.has sound.cannot change
U have cable,some kind of pay tv?Tries unplug the cable box,replug the box for reset or to update new solfware for the box.If u have free air tv,get better antena like out side door antena or a digital antena.Also should change the batteries in ur remote and clean the IR lights both remote and tv make sure no blocking path to signal.
Oct 31, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Picture is frozen
There is a button on the lower part of the remote that is a "freeze" button, it will freeze the picture, or capture a still shot. Try pressing this button to "unfreeze" your picture.
Jan 13, 2009 | Akai LCT3285TA 32 in. LCD Television
SVA-USA VR-20 20 in. HD-Ready LCD Television Logo
13 people viewed this question
Top SVA-USA Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Al Clark
Are you a SVA-USA Flat Panel Television Expert? Answer questions, earn points and help others
