I just bought and hooked up a 2.5 ton all in one package heat pump. but the heat pump only works on emergency heat, what is my problem
  • ashmtl08
    ashmtl08 May 11, 2010
    When you say all in one, what is in the package?
    The alternate heat is in it? What is it oil, gaz, electric?
  • 700 Answers
Recheck the wiring on the thermostat and at the package unit to be sure that nobody took and wired them incorretly so that the heat worked.
Posted on Mar 21, 2009
I have a 5-ton Nordyne heat pump. The compressor has quit working. How can I get the emergency heat strips to come on using emergency heat on the thermostat.
Your thermostat should have an emergency heat setting. Putting the thermostat in that position should make the electric heat strips only work and keep the compressor from coming on. If your thermostat doesn't have an emergency heat selection disconnect the compressor outside at the power source. Turn the thermostat 5 degrees Above the Rim temperature the electric heat strips should come on.
Jan 02, 2018 | Heating & Cooling
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Emergency heat on, compressor not running
Unit may have have iced up and defrost timer came on which is emergency heat check pressures and refrigerant
Dec 19, 2015 | Rheem 3 Ton 14 Seer Package Heat Pump -...
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fan on...
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
Nov 26, 2013 | American Standard Heating & Cooling
OD model#, CKL36- 1F and the indoor model#, AR36-1. The indoor does not have the electric heat strip in it but has the place for it. I want to convert it to a heat pump. Is it a 3 ton system? How many KW...
You can use the existing air handler for a heat pump condenser unit up to 3 tons. The line set, evap coil are fine for a heat pump.
The electric heat strip issue can be another problem, you can put several different size strips in depending on what may be needed where you live, the power requirements will differ with each heat strip, for example a 5KW (5000 watt) heat strip requires a 2 pole 30 amp circuit for heat strip and air handler combination.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
Its 28 degrees out side and my goodman 3.5 ton heat pump package unit is blowing cold air out of all my regesters
Sounds like the heat pump is not running. Check outside to see if the fan is spinning.
Try moving the thermostat to emergency heat and see if that gives you any heat. If it does, then you have heat until you can get a service technician to locate the problem with the heat pump. It could be a wide range if issues from bad thermostat to bad wiring to bad capacitor.
Jan 07, 2010 | Goodman Heating & Cooling
Amana Heat Pump Emergency Heat will not come on
the problem sounds like 1 or 2 things either you have a bad sequencer for the heat strip or the emergency heat portion was not wired up.
Jan 30, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
