Question about Poulan Pro Chain Saw 46cc 20"
How do I remove the clutch on an Echo chain saw??
I need to remove the engine and can't get it out until I remove the clutch. Do I need a special tool?  What direction does it turn to remove it??
  • floyd_reed Jan 02, 2009
    I have a ECHO CS 510 and i need to remove the clutch to replace the sprocket how do you remove it?
    Problem Solver:
  • 4 Answers
Backwards to the rotation of the motor, all you need are basic tools to do this.
Posted on Dec 16, 2008
  • soupofdefish Feb 09, 2011
    You need a piston stop and a clutch removal tool. Most echo's you loosen clockwise.
How remove sprocket on echo cs400 chain saw, bought clutch removal tool and put rope in spark plug hole but doesn't turn to come off.
The last chain saw clutch nut I removed was left-hand thread meaning you turn it clockwise to remove. The clutch is then still tight on the crank and when put under tension from the clutch removal tool needs a tap from a hammer to break the taper loose.
Dec 08, 2017 | Echo Garden
Replace clutch spring
You need to remove the clutch assy from the chainsaw prior trying to replace the spring. Be aware that the clutch assy is no longer available so be careful not to damage it on removal.
Mar 01, 2015 | Echo Garden
How do i replace sprocket on echo 370
They have this on the ECHO website. Go to the FAQ page here: http://www.echo-usa.com/faqs/
You can find it by typing in 237. That's the ID # of the answer. Or you can just type in sprocket.
Jul 23, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
The chain on my Echo saw is moving very slowly to not at all
Your centrifugal clutch needs to be replaced or your chain guide (bar) is pinched.
Mar 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Replace the oil pump in a Echo CS4400 Chain Saw
An IPL for a CS4400 Chainsaw can be found here (there are multiple IPLs, please ensure this is your saw):
EchoUSA
http://www.echo-usa.com/documentation.asp?Model=cs4400&lang=E
There is no sigle illustration of all oiler components, they appear on multiple illustrations.
From the IPL it has an outboard clutch, it appears the oil pump is behind it. Use this a guide for clutch removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
You can reply below with any questions if you need additional help. I hope you found this most helpful.
Lou
Jan 31, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo chain saw sprocket not turning.
A few clicks form here will get an Illustrated Parts Manual, I find them them helpful.
EchoUSA
http://www.echo-usa.com/faqs.asp
If I read the pictures correctly it has an outboard clutch, this may also be helpful.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
Nov 11, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Oil leaking from the bottom of gray panal under clutch, I have checked for engine casing cracks too!!
I suspect your oil pump leaking or hose connection is leaking. You can probably find a parts breakdown with oil system detail for your saw here: If your model isn't listed please contact them and request it be added.
EchoUSA
Most Echos have outboard clutches (chain between the clutch and engine) this should help with removal if needed.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Nov 04, 2009 | Echo Garden
Trying to replace gear on echo cs 440 chain saw and not sure how to remove old gear
The IPL for a model 400 Echo can be found here:
http://www.echo-usa.com/pdf/documentation/CS400_C090_11_081007.pdf
It should not matter but please verify this fits your serial number.
From the IPL your saw has an outboard clutch. Use this the following as a guide. I didn't see any special tools on the IPL.
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
    Lou
Jul 02, 2009 | Echo Garden
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Pro Chain Saw 46cc 20" Logo
1,223 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
