Question about Samsung HCN653W 65" Rear Projection Television
Samsung HCN653W 65 in. lines.....lines.....help!
My set has annoying lines that run accross my screen from side to side, about 2-6 inches wide and they have a brighter picture to each line. I tried all the inputs, and its the same if your watching a dvd, or sat. I ajusted the brightness way down so i wouldn't notice them as much. Also when there is wording on the screen, it creates bars that are darker all the way accross the screen for each line of wording. It seems that those bars are the way the picture supposed to look. before i call to have it looked at, i wanted some ideas of what it could be, so i'm not fed a bunch of bull. Is it something i can fix myself?? i build cars and bikes for a living so i'm handy, i just don't know where to begin and don't want to make the problem worse. Is it fixable?? or worth it?? i hope so i love the tv!
  • Mike porcaro Mar 23, 2007
    they don't seem to move at all. Just a brighter picture in between the line. Than darker, than brighter. Its like the brightness level is way up on the line than after the line its the way it should look ect.... ect.... And like i said when there is lettering it is dark lines accross the lettering. So if there is cdedits rolling up the screen from a movie, each line of words the picture seems perfect.
    President:
  • 1,284 Answers
Sounds more like a power supply issue than a convergence problem. Do these lines move and go from bottom top the top slowly or from top to bottom?
Posted on Mar 22, 2007
  • 67 Answers
My first guess is it kind of sounds like a convergence board problem i know they had some service bulletins on them. hope that helps oh and convergence boards arent exactly cheap and will probably require some soldering
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
It has kind of like blurry lines going accross the screen?
my tv also had wavy lines when running thru the cable jack or your standard RCA jacks. i used a S Video cable to hook up my cable and dvd player... with no lines. they are about ten bucks at walmart one of the componets on the signal board.. my dvi also works without any lines. just for the record ihave been fixing tv's in my garage now for about a year all these experts say they cant fix that with this model tv i'll try picking up a parts tv and changing what i think has gone bad inside this tv and let everyone know.. but i have told you a way to get around it and get back to watcing your tv without any of those annoying lines
Jan 25, 2010 | Samsung HCN653W 65" Rear Projection...
I have a samsung 65" rear projection TV. Model# HCN653W. The sound is find but the picture is now concave from left to right. For lack of the proper terminoligy it looks like you are looking at a bowl with...
Replace Both of your STK ICs Big black ics will have part number on them example STK392-110 also there is 2 resistors 2.7 ohms near STK replace them Call Mats for Parts 1-800-628-1118
Dec 14, 2009 | Samsung HCN653W 65" Rear Projection...
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Red lines when watching DVD
Regardless of what inputs you use when the lines appear, that symptom suggests that the Proscan Module Samsung p/n#BP95-00140T is probably defective. That board is a plug and play replacement but there are no short-cuts to testing it to be certain that's the problem or the entire problem. That said, the top of the metal shield lifts off and the board can be pulled with no greater skill than a first year technician. The board is $184.25 plus shipping from Vance Baldwin - so if you're feeling lucky you could try this one yourself... Just be careful. If you have ANY questions drop me a note at premtech@willapabay.org and include the model number. Hope this helps Bill Good luck
Jun 05, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W Transport
the bottom stand seperates from the top screen portion. On the side under the top potion you will see 4 black phillips head screws on each side. Remove those. Also there is a small access panel on the right side ( if your facing the tv ). There are 2 screws there, remove them , and look inside , you will see 3 plugs. Unplug them. Once you have done all this, have someone help you and lift the top portion off.
Mar 17, 2007 | Samsung HCN653W 65" Rear Projection...
Bad signal board or something else?
You weren't very specific about your problem, but assuming you've tried different inputs and tried messing with the convergence setting, it may indeed be the signal board, and you may need to have it replaced. BTW these sets also have an issue with the dynamic focus circuit and with crt fluid leakage. Make sure that you do not have a fluid on one of the crt boards. And as always with repairmen, a second opinion couldn't hurt.
Apr 04, 2006 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
133 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
