Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Pip I have 3 smaller screens on the side of the main screen paying diffrent channels my child had the remote and i lost my manual in the move how do you turn off all pip and just hane one full screen?
    President:
  • 1,284 Answers
On the front of the TV while it is on, press on the ACTION and POWER buttons at the same time and hold them for about 5 seconds until the screen goes blank and comes up with a diagnostic screen. Once that happens release them and press action again to clear the diagnostic information. Now your TV is se back the way it was brand new so you will have to proram the channels back into memory and apply your color,brightness,hue etc..settungs as those have all gone back to factory as well.
Posted on Mar 22, 2007
SOURCE:
I cannot get the picture-in-picture off the screen
Hello
You must press function before you can control PIP with the yellow labelled buttons.
Press to change the TV channel in the window picture.
Press to move the location of the window picture [counterclokwise] around the main picture.
Press to freeze the window picture with Freeze button.
Press freeze button on the remote handset again to restore the previous screen.
Ok
Oct 26, 2010 | Sony KV-27V65 27" TV
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
PIP change
you can change the channel of the small screen .just read the user manual of your tv.to your problem is only in the remote control
Oct 13, 2008 | Zenith Z32X31D 32" TV
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and +
buttons located near the bottom of the remote. You can swap picture in
the Main and Sub screens using the swap button and swap which screen
will sound off its audio by using the AUDIO button. You might notice an
X next to some of the selections in the INPUT and PIP INPUT screens
when you have PIP activated. That means that input selection is
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
bring up that input menu you will see X's next to the TV and AV
selections. The X's mean that when you have TV on the main screen you
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
How do you get to diffrent tv station to show at the same time (pip)
If your TV has built-in Duel Tuner then you can see 2nd picture in pip. In remote you have channel up-down button for main picture and another set of channel up-down for pip function to change channels in pip.
Sep 28, 2008 | Televison & Video
Changing channels on pip feature
I THINK YOU HAVE TO TRY TO SOLVE THE PROBLEM WITH THE REMOTE CONTROLLER SHOULD BE  FIND A KEY FOR
USE PIP
Dec 06, 2007 | Televison & Video
Problem with PIP Function
To turn off PIP. Use tv menu and auto set channels, once searching for channels, turn off and PIP will be gone. If you can't access auto program tune tv to channel 3 and try again.
Nov 24, 2007 | Sony KP-53V75 53" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
PICTURE IN PICTURE TV RCA
The PIP puts a smaller picture on your main picture. Usually, the smaller picture is generated by a second source, such as a VCR. The VCR must be connected to the main cable signal and connected to the TV through the red, white, yellow RCA jacks. The VCR picks the smaller picture whilt the tuner in the TV picks the main pucture. The PIP circuits digitally add the smaller picture to the larger picture. The PIP cannot be used to veiw 2 different channels at once on satellite systems because the satellite receiver sends only one channel to the set at a time.
Aug 22, 2007 | RCA F32665 32" TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
