Question about Epson Stylus Photo R220 InkJet Printer
I have an Epson r285 and I am trying to print some final prints on Epson Matte paper, but the results are ridiculously dull. I know that to get the best results with a printer you are meant to use their paper so why is my printer producing such poor results?
  • 81 Answers
In order to get the best results, besides using the best paper, you have to tell the printer to use the higher quality setting.
Assuming you are using Windows, Before sending your work to the printer, go to control panel, click on the printer folder and select the Epson R220. Right click on it and select "properties".
You'll get a windows with several tabs. Select the one that refers to the quality of the output, and be sure is using the "best" settings. (these pages vary from printer to printer, bat I hope tou understand the idea).
Then proceed to print.
Posted on Dec 16, 2008
I have a Epson pro large format 9600, I print on canvas, I have use Photo black since I have it, but never getting a saturation ressult. I have been counsil by Epson to use Matt black rather than Phot
"Photo black" is designed specifically for glossy photo paper. Matte black is for non-glossy paper, including plain paper. Matte black will print darker on non-glossy paper than photo black does.
Oct 28, 2014 | Epson Office Equipment & Supplies
First time visitor. Entered Epson Stylus Photo R285 into search box. As I scrolled down what I presume is the result of my search, there were answers for everything BUT my R285. I use a CISS kit on my...
Welcome to FixYa.
This occurs when the ink pad counter times out and is supposed to be a dealer service to drain the waste reservoir and replace the pad.
The only thing that you can do is try to reset the printer. Please do the following:
  • Turn off the printer by pressing the power button. Check to make sure that the print head is in the default position, to the far right of the device and locked in place.
  • Hold down the paper feed button. Turn on the printer by pressing the power button.
  • Release the paper feed button as the paper feed light starts to flash. Immediately hold down the ink-drops button for 15 seconds.
  • Wait for the printer to complete its test run. Turn off the printer and then turn it back on once more.
Thank you for using Fixya, keep me posted.
Jas247
Aug 23, 2011 | Epson Stylus Photo InkJet Printer
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson 10,000 won't print on posterboard
Prints on 44" Wide paper up to 1.5mm thick
Does this help at all?
May 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson r285
HI
Try reinstalling the inks, make sure you here a click when you press it down. If all fails you are having a hardware issue. call epson for replacement.
Hope this help
Dec 31, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r285
open your document and click print, then click on the properties button.Then click on the page layout tab and uncheck the collate button.
This wil print each page on a new piece of paper, the collate option is to print on both sides of the paper.
Aug 08, 2008 | Office Equipment & Supplies
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
