Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Water in bottom
After the wash it will emty but if you check it later there will be water in the bottom??/
  • popofarm Dec 16, 2008
    no it is a cup or two in all the time. never gets more. i have checked my trap and not plugged.
  • ashmtl08
    ashmtl08 May 11, 2010
    If you do not use it, will the level rise in time?
  • 4 Answers
This sounds like your backup valve is not closing properly, so the part of drainage water comes back into your dishwasher. You can verify this by disconnecting the drain hose from your kitchen sink drain and pouring water into it. If some of it comes into your dishwasher, the check valve (backup valve) must be replaced.
Posted on Dec 16, 2008
Why wont it empty
something is maybe jammed in the pump rotor,it is usualy just behind the filter
Jan 24, 2015 | Washing Machines
My washine machine will not emty the water
Check the filter for blockages and the pipes if they are ok may be a pump problem
Jul 15, 2014 | Washing Machines
Hotpoint wf320p washing machine leak
pull the plug
check the pipes from the soap dish to the tub
Feb 09, 2014 | Washing Machines
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
I ran a rinse cycle on my washing machine (top load) last night. When it was done, I went into the laundry room, and there was water on the floor, in the hall and in the adjoining bathroom. The water was...
check your connections on your hot and cold water taps that connect to your machine check youy drain connection if all is ok then it is your pump
Feb 27, 2011 | Washing Machines
Radiator water tank always emty
to know for sure a raitator tester would find a leak for you it goes on where your cap is you pump it up and it shows a gauge for the lbs if the pressure goes down there's a leak and with alot of pressure it will make a sound of where it's coming from. good luck hope i helped
May 08, 2010 | 2001 Mercury Sable
MACHINE NOT EMTYING WATER , BUT NOT ON ALL WASHES. DOES ON A FEW AND THEN WILL STOP. CANNOT REMOVE FILTER TO CHECK IF BLOCKED.
"Cannot remove filter" - that's a good sign it IS blocked.
Tipping the machine on its side or back may cause debris to move, allowing you to unscrew the filter.
Alternatively, remove the pump motor from the housing (tools needed) and clear blockage.
Feb 27, 2010 | Washing Machines
Washer does not complete its cycle on any wash cycle. Error Code F 02 shows up before rinse and spin is complete. Clothes are soaking wet. What is the problem?
check the drain hose for any blockages or kinks and check to make sure water passes through it freely. it may be that it's just not emtying quick enough and therefore clothes remain wet. in a worse case scenario the pump itself could be faulty :(
Oct 27, 2008 | Whirlpool Washing Machines
Washing maching won't continue cycle
Check that the front door or lid interlock switches are operating. If they are not, the machine will not start. It is a very common cause of non-operation, and simply opening and closing the door will usually clear the problem if it is just intermittent sticking.
Jun 05, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
189 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
