Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water pressure On my Frigidaire refridge side by side how do I turn up the water pressure on the water despinser?
  • mcarr2277 Dec 21, 2008
    Great advise but, no dice. Still unable to get pressure.
  • 161 Answers
There is no control to turn the pressure up.
Start by checking the water supply to the Ref.
1. Turn the water supply off and disconnect the water line at the back of the ref.
2. Turn the water back on and fill a small pan with water to observe the pressure. low pressure here then replace the tap valve on the cold water line. If the pressure is ok then the problem is in the ref water valve.
Posted on Dec 17, 2008
  • Ron Buice
    Ron Buice Dec 21, 2008
    I keep a spare section of plastic water line so I can disconnect the Ref water line at the water valve on the back of the Ref and hook up my spare water line then, I can press the water fill button and fill a glass from my water line. If the pressure is low then I know the valve should be replaced. If the pressure is good then there is a problem in the water line between the valve and the door.
    I think the problem is with the water valve.
Milk freezing
Need more information, but try turning the fridge to normal and the freezer the same. Try placing those items in another location. Problem could be a bad air damper.
May 10, 2015 | Frigidaire FGHS2631PP Gallery 26 Cu. Ft....
Smells like frost
Baking soda, follow the directions on the box for use in freezer or fridge.
Aug 04, 2012 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
I just replaced the water filter in my frigidaire and every time i press for water it flods out of the filter
I had the same problem when I went to change my water filter. Once I changed my filter - the water now gets backed up in the system and water now leaks through my filter into my refridg. I have to take out the filter to stop the leakage. I call fridgeaire and they said every time you replace the filter you have to purge the water system by taking out the water supply in the back of the frige - pruging the system then replace the filter. This still hasn't worked and in my opinion a defect in the fridge. Please let me know if you heard any solutions.
Oct 06, 2010 | Frigidaire FRS26R4A Side by Side...
New refridge
The book says it can take 24 hours to start making ice, but normally only a couple of hours. Make sure the you have water coming to the fridge, then check on any warranty. Your fridge has a energy recomended setting that will be fine.
Jan 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Order in drain pan
its supposed to have water in it heat from the compressor evaps the water you may poor a little bleach in it to kill the algae or bacteria to help with oder
Jan 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Amana French door Refridge-water dispence inside the door not working
pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Jan 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
305 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
