Question about Toshiba M674 VHS VCR
Audio recording not very loud in play back
I have my VCR attached to cable in and then out to a TV. The video on programs records fine, but the audio is not very loud ie I have to turn the TV volume way up in play back in order to hear it comfortably. Is there anything I can do to increase the volume level in the recording?
  • 979 Answers
You may have a tape alignment issue, but, before you try anything rash, have the "control head assembly" cleaned. If you're not squeamish about opening this, you can then load a tape and look to see if the very top edge of the tape is "curled" over anywhere from .5" or greater. If this is the case, you'll need to fix what's causing that before you can do anything else....accordianman
Posted on Dec 16, 2008
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
How can I get audio and video out from my tv if it only has audio and video in.I'm trying to connect a dvd recorder to record programs off the tv but tv does'nt have output signal.
connect dvd input cable (three banana plugs red, white, and yellow) to the video and audio output on a vcr, then take a screw on cable from the Ant. to the vcr. you will have to tune the vcr to the programs channel to record the picture. The vcr manual should tell you where the signal will be going, The picture should also go to the tv on ch 3 or 4 as when you play a vcr tape.
saddikins
Aug 05, 2009 | Televison & Video
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Audio
Does it play back professionally prerecorded tapes okay? Does that VCR have a HiFi stereo option? What is the brand name and model number of the unit?
Apr 24, 2017 | Panasonic PV-C1331W 13 in. TV/VCR Combo
Toshiba M674 VHS VCR Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
