Question about Amana ARB1905C Bottom Freezer Refrigerator
Amana BRF20 - freezing in fresh food drawers
Although the temperature is set a "1" and the rest of the refrigerator compartment is a good temperature, the items in the fresh food drawers keep freezing. Also, there is a hole in the back of the compartment between the two drawers in which there is a plug. The plug gets pushed out, by ice I believe.
  • Anonymous May 20, 2009
    used to be just the left drawre, now it's happening to the right one as well. Seems to oocur when food is placed on the shelf immediately above the drawers. It's not a door issue.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check your door not closing stay (ajar)
Posted on Apr 01, 2009
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Refrigerator freezing food
Ah... where is that manual when you need it! Actually, the internet is WONDERFUL for such emergencies! I found a manual on the FixYa site for you in pdf format. It will be easier to find on your computer!
Now to the soluiton...
Generally with the top freezer designs the main thermostat controls the temperature of the freezer (which should be about -18°C or 0°F and the there is a slide control that allows a metered amount of cold air to drop down into the "fresh food" compartment.
As an immediate adjustment, turn the "Fresh Food" slider down 1 number LOWER that what it is set to at the moment. Is fresh food still freezing? Then put it down another number lower.
But you should also check the temperature of the freezer compartment with some appliance thermometer... leave it in for several hours or overnight for a proper reading if you've just added food to the freezer. It should be around -18°C or 0°F If you adjust the freezer, you may have to go back and readjust the fresh food setting.
I hope this helps! Don't forget to download the digital manual!
/denis
Dec 10, 2010 | Amana ATB2135HR Top Freezer Refrigerator
My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
Contact an appliance service company.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Can the fresh food drawers be disassembled?
yes they can be disassembled but it should not be special temperature drawer or zone which can be independetly controled otherwise you can change the temperature deviation in the compartment which can lead colder temp or below freezing .not good for the fresh food.
Jul 01, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Dec 26, 2008 | Amana ABB1927DE Bottom Freezer...
Amana ARB1905C Bottom Freezer Refrigerator Logo
888 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
