Question about Sony KV-32S26 32" TV
Multiple video inputs
I am trying to use both video inputs. My DVD has an s-video connection which I connected, through my reciever, to the back of the TV. My VHS and Satellite input are also connected to my reciever though not through s-video. The s-video cable from my receiver does not carry the signal from my VHS & Satellite. When I connect a conventional video cable from the receiver to the TV (leaving the s-video cable still connected) the TV does not recognize the signal. When I remove the s-video cable and leave the video cable connected the TV recognizes the signal from the Satellite & VHS. Is there no way I can have an s-video cable and conventional video cable connected to my TV at the same time with the input signals changed through my reciever? My reciever manual shows both cables connected at the same time to the TV but this is not working. Any help would be appreciated.
Just fitted satellite dish have bril signal but receiver is saying no video signal ?
Posted on Jan 29, 2009
  • kevlaver Jan 29, 2009
    i have just fitted satellite receiver and dish to astra 2,have bril signal but no picture and is saying no video signal ?
    Scholar:
  • 135 Answers
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Posted on Mar 22, 2007
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
I own a rca tru flat model 27F520T and the tv signal is via a starchoice statelite reciever. I recently purchased a Toshiba DVD SD7200. I am trying to view dvd's with the hook up to the statelite...
Try this steps
On the backside of your satellite receiver, you will notice a bunch of connections. If you already have your coaxial satellite cable connected to the INPUT on the receiver, leave it connected. Disconnect and remove the cable connecting the receiver to the television.
Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.)
Next, tune your television to the proper input channel. Look on the television's remote control for a button that is labeled "Inputs" or "A/V." Press it until you see the correct A/V channel appear on the screen. If you made your connections in A/V 1, then the TV should display "A/V 1" in the corner
Now, just turn your equipment on and settle back to watch your favorite show or DVD
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
I have the onkyo tx sr502, onkyo dv sp402e with the speakers..etc.. i'm trying to set up the whole thing to a normal television. that is, what cables go from what components, out/inputs..etc..and which...
Hi troy my names Josh i would be glad to be able to help you with your setup. First things first some people have a preference with they way they like things and for one do myself. I set up and intstalled my home theatre. I have receiver much like yours. On the back of your reciever you should have multiple inputs of coarse some for sound some for video. Your sound inputs would include digital optical, digital coax, standard analog which of coarse is the red and white RCA inputs and then a multi in which i doubt you have. So lets start simple If you have satalite or some form of cable i would assume you have your reciever box feeding a signal to your tv and the same for your DVD. I would recommend for your sat. that you connect your picture and sound strait to the tv rather it be component video or s video or standard video source or connect then for your sound strait analog to your tv thats just Red and White RCAs which will give you your sound to your tv. Repeat the same for your DVD depending on the kind of inputs and number of inputs you have on your TV. Now for the sound to your reciever. I ran digital sound from both my DVD and my Satilite to the reciever which means on the back of your recievers providing you have a similar configuration you would look for a plug on your dvd player that says optical thats your digital to run sound to your onkyo and the same for your sat or cable if you have a box look for either digital optical or a single digtal coax output that will also be ran to the onkyo for sound. You should only have two cables running to the onkyo one fiber optic from your dvd to the onkyo and one digital coax or fiber optic to your onkyo depending on the number of those inputs you have on the back of the onkyo you can run it how ever you want.
Oct 07, 2010 | Onkyo TX-SR502 Receiver
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
How do u connect the surrond sound on the blue ray dvd player
you are tring to connect the dvd to the reciever?
if so use the red, green, blue component connections plus optical or coaxial audio from the DVD to the DVD input on the reciever and the red, green, blue component connection from the reciever to the tv
Jun 16, 2009 | Denon AVR-3805 Receiver
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How to connect dvd player to AV reciever
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Jan 22, 2009 | Audio Players & Recorders
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KV-32S26 32" TV Logo
221 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
