Question about HP Pavilion dv6000z Notebook
My computer stopped working
The fan and power supply work beacuse when you connet an mp3 to charge it will charge it. the cpu once i took it off was all bend rom the pins..so i think thats the problem but im not sure. i want to upgrade my cpu but i dont know what processor my motherboard supports. i have an HP pavilion a 400n and i dont know the motherboard model or nothing about it.. the old porcessor it had was an intel celeron 2.7GHz
  • dreameraztec Jan 06, 2009
    well the monitor works and i know that for a factn so does the mootherboard
    Problem Solver:
  • 59 Answers
The screen might be broken because thats what happened to me and i got a new screen and it worked again try and do that or get a new mother board because if *********** board dosent work certin things on your computer wont work
Posted on Dec 27, 2008
Computer wont start, despite all components working, cpu looks corroded
Pat,
Usually you diagnose these by process of elimination. Get down to the bare bone mobo without anything but the processor, good RAM (switch out if you can with different ones), and Power Supply. Eliminate everything else, no cd, no floppy, no hdd, no video cards, no sound cards, no cards at all really.
More than likely it's a bad power supply. Take the power supply to your local computer shop and they should test it for you for free... don't let them charge you for it. If it's good then test the cpu.
Hope this helps :)
Sep 22, 2013 | Compaq Computers & Internet
My gateway computer do not turn on.the fan try to start and stop.what should be happenning?
I think that the CPU fan isn't working as it should and the CPU is overheating quickly. If the CPU is heating too fast, the mainboard is automaticly shutting down the all PC to prevent damage. Your thermal paste might be gone. Isn't the computer giving any sounds or LED flashes ?
Nov 02, 2010 | Gateway 830GM power supply **FREE **...
My psu is working fine. its coolmaster extreme power 600w. when i connet 24 pin conneter its ok. but when i connet 4 pinch connector no move from any fan. whats wrong
Hi, well that connector, is the High Current 12 V DC supply for the CPU, Power Distribution.
Now IF the PSU is shutting down when this plug is inserted, then you MUST have a problem with that Circuit, either the CPU, and/or the Power Conditioning circuitry supporting the CPU.
Often is is the actual CPU itself, has failed and/ or the Vregs, Or The Electrolytic Capacitors, right by the CPU socket.
When this happens, IF it is ONLY the CPU, then a repair can be effected.
If it is the Vregs, and/or the Capacitors, then less so. in that case a new MB would most likely be in order.
I have repaired some Gassed Capacitors and Vregs on the MB's itself, but this depends on price of initial price of the MB, the actual faulty components, and the cost and availability of said components. usually a new MB is in order, as we do not want to put a new CPU into the repaired board and have it destroyed, which can easy happen.
Aug 30, 2010 | Gateway E4300 (E43001008508) PC Desktop
When i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop, power supply fan also turn few times and stop and computer does not start.
Possible bad power supply, hard drive, and or CPU. If there is a computer repair store close to you, I would take the hard drive to them and have it checked out thoroughly to make sure all the sectors are in tact and possibly have the power supply OHM'd to make sure the proper amount of voltage is coming out in order to turn the computer on in the first place.
Oct 11, 2009 | LG L1915S 19" LCD Monitor
Cooling fan stopped, supply overheats
Most probably it is fried. Take out the power supply. Then test it if it will start by shorting the power on wire to ground wire for a short time. Then read the voltage readings on terminal output of power supply that connects to the motherboard 2O pins header. If within spec then change the supply fan. If not then buy another one it is more costly to repair than to buy a new one.
If you don't know this have a friend with knowledge assist you.
Goodluck
Oct 10, 2009 | Antec TPII-380 (TPII380) 380-Watt Power...
My cpu flash a green light in the back, and the pc wont cut on. took it to the shop and they disconnet the mother board and connet it back it work. i took it home and connet up my pc up and it wont cut on...
Since you brought it to the shop before. I would recommend you call them first and tell them it is not working once you brought it home and can you bring it back for them to test again. Also it is a good idea to turn on and off once or twice before taking it back to make sure it works
May 06, 2009 | HP Compaq FS7600 17" CRT Monitor
Yp-k3 is not being funny
when bang it on the table one time then turn it back on in like 5 minutes then it should work cuz it happened to me....
Jul 24, 2008 | Samsung YP-K3 MP3 Player
P4vmm2 motherboard wont start
cheak and change ur power supply
Jan 05, 2008 | EliteGroup P4VMM2 Motherboard
No respons at all !
I think your power supply cables is not able to start your B-board if your power supply is working properly then check mother board jack where you insert your power supply plug in M-board. Then you have to change or repair that jack where you insert power supply wire in M-board. With best regards M. Khalid Shaikh from Pakistan Mobile: +92-332-2631983
Sep 19, 2006 | Intel Desktop Board D845BGSE Motherboard
HP Pavilion dv6000z Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
