I am moving an older hitachi tv, model number CU5002K. Are there any safety precautions that need to be done to the tv before moving ~ it is a 50-inch tv, and being older it's quite large.
  • 121 Answers
Keep in upright postion. try not to jar. remove bottom front panel speaker cover, can blow off.
Posted on Dec 16, 2008
Sanyo 1LG4B10Y04800 how do I find out what board my television takes this is the Power Board number
Assuming you are observing all ESD & Safety precautions...
The absolute best way to tell what pack you need is to LOOK at your old pack...
Go to a parts supplier...
Put in your make = SANYO
MODEL = something like "DP42841"
that ought to be a Sanyo Lcd tv ...
such as ... shopjimmy.com
ebay.com or amazon.com
Sanyo 1LG4B10Y04800 Power Supply
TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 16, 2016 | Sanyo Televison & Video
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
Tv wont turn off completly
A better description and model number are needed----Some older Hitachi sets when turned off will appear to go off but the power light will remain on............?
Nov 01, 2012 | Hitachi Televison & Video
I have an older gun can't read any specs the lables are worn off, the guns safety plunger is sticking allowing for free fire of the gun. most of my other guns have a step plunger with the spring r
To find the model number, look on ebay for hitachi framers and hopefully you will find one listed that looks like yours. If no joy, take the gun to your local fastener/nailgun dealer for parts. The dealer most likely has box full of used parts for your gun. I have seen many older nailers with bent safety foot that caused the plunger to stick in the engaged position. Some nailers have the safety return spring incorporated within the trigger plunger /valve area and still others that have the spring hidden under a guard on one side of the nailer (guard part # 883493). Look under the main body of the nailer for an indention where one side of the safety spring fits into (less than 1/2 inch in diameter) ; directly below the indention will be a point on the safety foot to catch the other side of the spring. Good luck
Oct 22, 2012 | Hitachi 3 - 1/2" Full Roundhead Framing...
Need Hitachi LE42XO04 LED TV manual
Hello
Just look at your problem post first. There is no details about this Hitachi model either in internet or at Hitachi websiite. Either you may have posted with a worng model number, or you may have been cheated by somebodey with giving you this set, as Hitachi. Hitachi has no LED TV with this model number[LE42XO04]. I can't see it nowhere.OK.
Dec 12, 2011 | Hitachi Televison & Video
My husband lost the safety key for our Hitachi Table Saw Model Number C10FR. This saw is discontinued and the customer service department at Hitachi will not return phone calls or E mails. Can anyone...
I found Hitachi customer service to be quite helpful in replacing my safety switch for my C10RA2 table saw. My C10RA2 has a fixed metal stand, not the folding stand, and the part number for the red safety switch or key is 531-992R, while the switch itself is part number 314-459. If you have the folding stand the part number for the switch is 321-620 and the safety key is 321-621. Hitachi customer service in US: 1-800-706-7337. I am going to buy two or three! Almost lost a table saw over a cheap plastic part.
Dec 27, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
Picture is wavy then fine, happens every two minutes
This model like several others had problems with what is called a Hyper board inside which processes all signal inside the set.
From a Toshiba service bulletin:
No: PJTV200503 2 Pages Ref: WU032505
Product: Projection TV Date: 3/25/05
Models: 42H81,43HX71, 43H71, 50HX81, 50H71, 50H81, 53HX71, 53H71, 57HX81, 57H81, 61H71, 65HX81 AND 65H81
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may-be liable for any resulting damages and may expose themselves and others to possible injury.
Application: The information contained in this bulletin applies only if you encounter the symptom(s) listed below.
Subject: MVPU13 Hyper Module Repair (23786198 / 23148017X)
Symptom: Multiple Symptoms may be experienced depending on which capacitor is faulty. The primary symptoms are jagged, digitized or pie crusting of the picture. The set may also be described with a poor sync condition.
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040 as shown in Figure 1. It's recommended that all of the capacitors identified in Figure 1 be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.)
TOSHIBA AMERICA GOISJSUIVIIER PRODUCTS, L.L.C.
There are several surface mounted capacitors that dry out with age and usually the problem starts out when first turned on and then eventually after on a long enough time the set works--the time will get longer as the problem gets worse.
The board is no longer available and only two options here: locate and replace all the selected caps which is not a do it yourself job or remove the board and send it out for rebuild.
Let me know if you need more info as I have seen dozens of these sets with this kind of problem.
SD TECH
May 13, 2010 | Toshiba 57H83 TV
NEED INSTRUCTIONS . LOST DURING HOUSE MOVE
Try the Hitachi website. Some makers provide them free as a PDF. You will need the model number, if they don't you could also post the model number on here again and see if anyone has a copy of your model.
Mar 23, 2010 | Hitachi Televison & Video
Color and foucus is not right.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Toshiba 50H72 50" Rear Projection...
Open Questions:
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
