Question about Watches
I have a little girls carousel that needs the top fixed, i cant seem to find anybody that does this. People keep telling me jewlers.
  • 2,338 Answers
I suggest you have to find the decent watcmaker. Clokmaker would be even better.
Despite of being under one roof for ages, watchmaking is completely different trade to jewellers and jewellers wont be able to help you.Regards
Arthur
Posted on Dec 17, 2008
Anyone know which battery for ADIDAS watch model ADP 3014 ? thank a lot
If you take it to a jewler they will open the back and tell you for free. They may even have a replacmant battery in stock .
Oct 02, 2014 | Adidas Response Sequence ADP3014 WW Watch...
My father has a pocket watch from 1904, well that is what is engraved on it. On the face of the watch says Hampden, and is in numeric, and has a round small seconds piece. On the opening of the watch the...
Take your watch to a jewler for proper evaluation. While there, have the watch cleaned, oiled and adjusted as may be necessary.
This is a repair site ... few here are equipped top properly give you any estimate as to value of your watch.
Apr 15, 2011 | Watches
Broken watch band TH 6000 WH1151
This has happened twice to me. First time they said no alternative but to purchase new strap.... £850!!. Second time watch is in drawer and I am so fed up I have not even bothered to take it back again as I know what the answer will be and I cant afford to pay that again!
Oct 05, 2009 | Tag Heuer 6000 Quartz WH1151.BD0678 Wrist...
Where can I get a crown for a ch 2454 fossil other than fossil, they don't seem to have any!?
go to a local jewler they'd be the ones to be able to help you get a new one or repair your old crown it probably just needs to be sodered if just the crown and not the whole crown assembley
Oct 01, 2009 | Fossil CH2331 Wrist Watch
I have a watch i need to take links out
I have a similar watch band and the little grooves are really not for screwdrivers. It is a split pin that just pushes out. I use a jewler's screwdriver or a small nail to push them out because I don't have a pin punch that size. Hope that helps.
Mar 14, 2009 | Watches
Link pins for a womens Fossil watch
The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
Oct 27, 2008 | Fossil Watches
Mossimo watch
Try this:
http://www.webjeweller.com/jewellery/removelinks.shtml
For my band, the trick is to use a 1mm jewler's screwdriver and push against the pin in the link. The pins exit in the direction of the arrow on the link (and go back in opposite direction).
Pushing on the pin can be tricky. If you slip you'll stab your finger with the screwdriver. It takes a little more pressure than you think, but once the pin moves it comes out easily.
Jun 21, 2008 | Watches
Geneve gold wrist watch
if no possible joints can be seen at back it can be open through glass.find an expert on watches.
Mar 21, 2008 | Watches
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 | Watches
Accutron Tahoe Chronograph
i have the same watch it needs a cleaning by a watch maker not jewler hope this helps
Nov 13, 2006 | Bulova Men's Accutron Tahoe Watch
Watches Logo
302 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
