Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
MY 1999 MAYTAG PERFORMA ELECTRIC DRYER STOPPED RUNNING.
katfishric on Dec 16, 2008
No, the breaker did not trip and Yes, the 240 is present at the outlet and the plug did not pull out.
I saw something said about a thermal switch. Is it located at the top side of the service panel (accessible from top)? If so, what should this component read when using an ohm meter? Thanks in advance!
Rick
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Jan 18, 2009
-   ABOUT A WEEK AGO IT STOPPED HEATING REPLACED ELEMENT RUN FINE 3 DAYS NOW WONT RUN AT ALL PLEASE HELP-   Guest
Best Solution
posted on Dec 16, 2008
Very Helpful)
TheMobilian
Rank: Guru  Maytag ExpertMaytag Expert
Rating: 88%, 429 votes
Well you need to get the lint ball out of the filter housing blower area. So you have to get the front off. To get to that limit you will also need to pop the top. The limit is in the rear on the right hand side of the heat element.It is mounted to the side of the heater chamber with a clip and the same long screw which holds down the heater element. The limit has to have continuity or the dryer will not run.The kit comes with 2 small limits(color coded) one is set for 250 for gas heat and the other is set for 300 electric heat
This blower wheel will strip out and cause the fuse to blow also. The cust will tell you it takes long periods of time for the clothes to get dry. To get into the dryer you start here:
Was this helpful?
Yes
No
Related Problems
OLDER MAYTAG HEAVY DUTY HOME DRYER DRYER WAS WARM AND HAD...
My dryer automatically stops and the door opens even if the...
I turn the timer to x amount of minutes and push to turn it...
The dryer seems to run fine but no heat. It also ran for...
Can you Help with these Dryer problems?
dryer wont start
Solve
dryer wont turn on changed timer door sw and motor did run for a few but then shut off and wont come... (More)
dryer stopped running while drying
Solve
dryer stopped running while drying and now it will not start. Outlet is supplying power.
Iwant to replace the fuse on my...
Solve
Iwant to replace the fuse on my Maytag dryer SDE515DYW. Only problem is I cannot find it!
Dryer won't start. I can hear the...
Solve
Dryer won't start. I can hear the timer but it won't go on???
Sponsored Links
Describe your Dryers problem:
Top Dryer Experts
Rank: Guru Guru
Solutions: 2825
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Dryer Experts
Top Washers & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
