Question about Coleman Powermate Powermate 5000W Generator
Powermate PM0435001 Runs no power out
Hey guys, GREAT SITE you have here.
Here is what happened, we were running for about 2 days with a never used 2 year old Powermate 5000, I was monitoring the amp draw through out the day and it would average around 11 amps on both legs that was until someone decided to turn on the DRYER "2 pole 30", well needless to say that is what brought me here.
I have dissembled the end bell and removed the circuit board and have done a lot of inspection of it and nothing shows signs of damage "cap is not swollen nor do the diodes show any type of discoloration" the board itself looks and SMELLS brand new.
One thing I found that does not seem to make sense to me is if I hold the rotor by using a wrench on the end bolt and then grab the windings behind the slip rings I am able to rotate the windings of the rotor, my question is could that be the problem or is this normal ?
I have checked the windings and this is what I found, 34 ohm across the slip rings, 0 ohms to the shaft and also the stator.
While reading through different posts I see where some people need to flash the unit with a battery in order to get output voltage, exactly what does that do, charge the cap, magnetize the windings, just curious ?
Last question, how do you go about testing the cap, does it have to be removed or is there a way to do it while soldered to the board ?
Thanks in advance to any that respond.
  • Coleman Master
  • 1,388 Answers
I worked at a tool rental center while going to college learned a few tricks trouble shooting generators. To test the circuit board apply 12 - 14 volts AC to the small two pin connector and read output at the leads to the brushes, you should get about the same or more voltage but DC. Capacitor should be removed to test properly if you suspect failure. It should read to 95 % of stated valve (Most caps for this gen are 470uf and will swell when failed). The armature should not slip on the shaft of the engine, you might remove the armature and check for damage or windings may not be fused to shaft. The armature is generally difficult to remove. We would remove the bolt and insert a hard steel shaft that would slip past the threaded part of the engine crank. Carefully Impact the shaft with heavy blow (use caution when hitting steel with hammer and do not miss.) It may be safer to remove the stator when you do this. Flashing the gen is generally only necessary when the gen has lost its residual magnetism. (If not used for a long period of time) To flash a gen we would use a small ac power supply 12 - 16 volt ac less than 1 amp, any small thrift store power supply will do and attach to a short piece of scrap male pigtale. Plug in the power supply to wall outlet and the short pigtale into the 115v outlet of the generator with the engine not running. (Some people will do this with engine running but not necessary) You will hear a slight hum in the stator. The stator will actually cause the armature to produce a magnet and voltage will be present across the commutator rings. Remove after a minute and the armature will regain its residual magnetism. This method will also test one of the 115v windings of the stator. If the winding is open there will be no voltage at the commutator rings. Good luck , enjoy.
Posted on Dec 17, 2008
Powermate 5000 dies after a couple of hours
You will need to contact Powermate directly (see below), and give themthe CORRECT model # info that you have there on that Genset.
Unfortunately what you posted above doesn't help out at all as there isNO model # for reference. Certain models are no longer available asthey have been discontinued and only by contacting Powermate directlywill you get the proper Operators Manual.
There should be no charge for this and most likely it will be a PDF download sent by their service dept.
The model # should be found either on the engine decal plate or else on the generator head assy or it's power panel.
Please post me a reply as to finding this solution being the bestresolve to your missing Operators Manual problem by following thecompany references & links below. Also please rate mytroubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Sep 22, 2008 | Coleman Powermate Powermate 5000W...
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ... > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
When chocked starts great and runs great, when you switch the lever to run it surges and dies
clean carburator i had same problem by running it on choke i only made the carb more cloged even though it seemed to run better clean the needle valve both holes now it runs like new
Oct 23, 2011 | Coleman Powermate Powermate 5000W...
I have the same problem on my 10 hp if it set for a long time , I remove the spark plug and put a drop or 2 of gasoline in the cylinder and reinstall the plug and wite and it starts o the first pull
Sep 07, 2011 | Coleman Powermate Powermate 5000W...
The gen runs great! but won't put out any power!
If the unit has been setting a long time then you may have to re-excite the rotor. The rotor can loose it's magnetism if the units sets for more than 6 months.
Do you have more information of what happened?
Oct 13, 2010 | Coleman Powermate Powermate 5000W...
Have older powermate 5000 contractor gen. runs great but only puts out 5.5 to6.1 volts. has new brushes
Hello. Plug something into your generator's receptacle, say a trouble light. Then check the output. With no load at all [nothing plugged in, you will get a voltage reading that is low. regards, Joe
Jan 28, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
1,358 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
