Question about Casio Parts Cash Register PC Desktop
THE RECEIPT PRINTER DOESN'T FEED THE PAPER
IF YOU PULL THE PAPER IT PRINTS BUT WILL NOT FEED THE PAPER ALTHOUGH THE LOWER GEAR MOVES THE UPPER GEAR ISN'T.
  • 737 Answers
Hi. Can you tell me the model number?
Posted on Dec 17, 2008
My shape XE-A207 cash register won't roll out the receipt paper when a sale is made. It is trying to print a receipt but the paper isn't rolling out.
Usually a broken feed gear in the printer. If you can hear the feed motor whirring but no paper movement, it probably needs a new printer.
Sep 07, 2015 | Retail Supplies
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
PAPER DOESN'T FEED THROUGH
check on the panel of the printer if the selected paper tray is the lower tray or the upper tray put paper on both tray mark the paper so you can see which tray is being feed,
Aug 04, 2011 | Canon LaserCLASS Fax 710 Printer
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Along with receipt an extra 6" of paper feeds parrell dos base program
In your accounting software is there a way to add a greeting or salutation to the bottom of your receipts? Something like Thanks for your business come again soon? I'm wondering if someone got into that part of the software and although they didn't actually type any greeting or message in there that the printer would print but maybe instead put in a blank area by hitting the enter key several times so that the printer saw the space there and created it? If that isn't a solution i'd need to know more about your accounting software.
Jun 01, 2009 | Matrix Star SP500 Series Receipt Printer
Timing, jams or prints off bottom of page
Hi hotpress:
Try these steps.
Print transfer jams
1.
If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
seated.
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
SB467.
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
May 23, 2009 | Xerox Phaser 850 Printer
It wont pull the paper through or my feed button will not work
it might be that the paper is not in far another ore there might be a paper jam
Jan 21, 2009 | Matrix Star SP200 Receipt Printer
Casio Parts Cash Register PC Desktop Logo
75 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
