Question about Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE Error Code : 2,178,0: I'm using a Toshiba tecra A6 laptop with the NTFS file system on the hard drive. The msg appears and ask me to release the lock, but its already unlocked. So I tried VueScan software which has built in drivers; it worked fine and it confirmed that there is something wrong with the canon original drivers and settings. I've tried to change the enviornment variables, as I tried by typing ;C:\WINNT\twain_32\CNQL20 and C:\WINDOWS\twain_32\CNQL20 in the Path. But it didn't work. I've Updated my windows xp and all the other softwares and drivers. I've re-installed the new drivers from the canon websites. As I live in karachi, Pakistan so there wasn't any website for Pakistan so I tried the singapore website, usa canon and canon uk. Didn't work. Please give me some advise as soon as possible. reply awaited. thankx!
Go to advanced tab in driver. Select calibration settings and execute
Posted on Feb 11, 2009
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Hi, I bought DELL INSPIRON 1545 in India two years back... now i am experiencing a trouble in it... It says the following error occurred: Error Code: 0146 Msg: Error Code 2000-0146 Msg: Hard Drive 0...
ok, the good news, the bad news, and the ugly.
Good news: buy a replacement hard drive and you should be good to go. Bad news: data recovery on a failed drive is a crapshoot at best- there are ways to try and recover, but they are stopgap (and cheap) or mostly reliable (and freaking EXPENSIVE)
Ugly: buy an external cage to install the hard drive, use a boot cd of Linux ( I've had better luck pulling files from NTFS drives using Linux than another install of Windows. Go figure....) and put the hard drive in a freezer bag- **** ALL AIR OUT OF THE BAG!. Put drive in freezer for 48 hours.
Pray. Pray hard. Pray harder still. Put drive in external cage, attach to linux system. Pull as much info as you can. Hopefully you can snag your important files- but that error is a pretty gnarly drive error.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 22, 2011 | Computers & Internet
When I try to load my recovery cd on an old toshiba tecra 9100 I get an error message about 30% of the way through the recovery . The error msg is ' Error- extraction failed'. Is this a hardware...
Sounds like software problem. Error on extracting the file from the recovery cd to the hard drive. But to make sure, run a diagnostic test for the hard drive if the recovery cd includes that option, if not, try another recovery cd.
Hope this helps.
Jun 11, 2011 | Toshiba Computers & Internet
Why can't my Toshiba ext hdd accept files more than 4GB? those files are .mkv formats. thanks!
The Toshiba is formatted with the 'FAT32' file-system, which is limited to 4GB per file.
Your 'C:' disk-drive is formatted with the 'NTFS' file-system, which has a much-larger limit.
So, use the 'DISKPART' command-line utility to "convert" the Toshiba from FAT32 to NTFS.
DISKPART is easy to use, but be careful to use it correctly.
Apr 23, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Toshiba tecra problem: disk i/o error:status = 00000400 ntdetect failed
This indicates you may be experiencing a pretty severe hard drive failure. I would recommend replacing your hard drive ASAP, and in the meantime, use your Windows OS disk to repair the windows installation to access your system again. No worries, done properly this process does not erase your files, only your system files that Windows uses to function.
Good Luck
Jesse
Jan 04, 2010 | Toshiba Tecra T9000 Notebook
A window appears saying "unable to scan. Be sure there is enough space in the destination disk."
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Sep 28, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
How Can I install drivers of my toshiba tecra
Copy and past the website I gave into the address bar on the top of the computer you are using right now. Download the drivers and save them onto a disk.Instal the drivers using the disk in the laptop. If you need the reinstall cd get it from this website also. You said you only need drives , not the windows also.
Jan 19, 2009 | Toshiba Tecra A6-EZ6311 Notebook
Tecra 8100
I'm not clear on your description, so here goes:
If it showed the Toshiba start screen, then asked for a password, then your hard drive is password protected.
If it showed the Toshiba screen, then asked for password, and you entered it, and then it goes "insert disk", then your hard drive is passworded and wiped.
If the first thing it does is ask for a password, then the password is in the BIOS.
Aug 16, 2008 | Toshiba Tecra 8100 Notebook
Toshiba tecra 9000 wont start
Blue screens are generally operating system failure. You will need to reinstall your XP home. Format the drive NTFS, instead of FAT32. If you have any problems during or after the reload, then the hard drive is the failure and will need replaced.
Jul 01, 2008 | Toshiba Tecra S1 Notebook
Canon CanoScan LiDE 25 Flatbed Scanner Logo
550 people viewed this question
old marine
old marine
