Question about Sony STR-DE335 Receiver
No Center Sound
I have a Sapphire center that I hooked up to my STR-DE335 receiver. There is only very slight sound coming from it. When people speak, it sounds really distant. The two Sapphire towers and Velodyne sub work just fine. I've never had problems with this center before. Is the center channel shot?
It probably isn`t :) it should be a problem with the settings :) i have a str de335 too and i get decent sound.. it depends on what type of source of input u`re using . try this.. hook up a stereo source. go into setup mode.. select wide or normal setting for center, then activate sound field .. c-studio for example.. if the sound is annoying something is wrong with the amp.. :-s btw use the delay settings from 1-6 6 if they are close together :) . When using 5.1 input... turn off soundfield always.. and triple check center settings&levels
Posted on Mar 27, 2007
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
I have a receiver sony str-de135, it is power on but the after a lillte while the protect annouce on the screen then the sound does not come out . ts that can be the trasistor problem or some thing else?
What is happening is that you have a component about to fail. as the component heats up it becomes intermitant or open. You need to take it to a repair shop
May 25, 2011 | Sony STR-DE335 Receiver
Sony str-de335 flashing protect when powered on and no sound comes out
Please see the link below for an explanation of protect mode. After that, please post here any additional questions that you have. Specific to your model, you can expect a parts cost in the $40-$60 range for the repair.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 20, 2011 | Sony STR-DE335 Receiver
Hello my sony audio/video control center #STR DE335 is in PROTECT MODE.. and i cant listen to it..can u please tell me whats wrong?
PROTECT display indicates that receiver got serious problem in output amplifier section and protection mode is activated to avoid further damage.
Output amplifier section should be tested by qualified technician to find out and replace defective part(s) to solve this issue. Local repair shop will do this job as it is not user level repair.
Thanks.
Apr 29, 2011 | Sony STR-DE335 Receiver
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
Jan 08, 2011 | Sony STR-DE335 Receiver
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Connecting dvdplayer. how?
connect the DVD video out to your TV video in, and connect your DVD audio out to your Sony STR-DE335 Audio in. In this way you can watch movie while listening thru your Sony's amplified sound.
Jun 13, 2010 | Sony STR-DE335 Receiver
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
Center Channel not Working
Check that it's center speaker in the set-up menu is on and that the sound field that it's in uses the center speaker. try it in pro logic. It could be a bad solder connection on the speaker terminal or on the relay in the receiver.
Feb 24, 2009 | Sony STR-DE675 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
Sony STR-DE335 Receiver Logo
209 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
