Have a gateway E2000 want to rebuild,
I would what size of power supply and what form factor mobo will fit the case
    Problem Solver:
  • 7 Answers
The e2000 has a speacial type of power supply. Replaces Gateway E2000 power supplies that use "Nina" chassis. http://www.atxpowersupplies.com/180-watt-power-supply-FSP180-51NIV-GW.php is a power supply i would suggest getting.
Posted on Dec 16, 2008
I want to upgrade replacement motherboard, what type or measurements size should I try?
ATX is the largest physical size mobo followed by the Micro. You wouldn't need to worry about anything smaller as they are more expensive anyway.
I would be inclined to replace the power supply also as that will be 'tired' and would probably struggle to power the new board. I never fit anything less than a 500 watt power supply. They're not that expensive anyway and it's always better to have power to spare than to be on the borderline.
Apr 25, 2015 | Computers & Internet
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
What is a form factor
The form factor is the size and configuration of a computers motherboard. Common form factors are ATX, and ATX Micro. The size determines the computer case that will accomodate the board. As wel as the power supply required to be used in the configuration.
Oct 11, 2012 | Computers & Internet
Would like to upgrade Gateway Desk Top 500SE to a HD video
I don't think you can't do that without some major changes. The 500SE is a small format computer. The motherboard only has 2 PCI slots so you need to match that interface. NewEgg still sells the PCI video cards but I don't think they are HD
http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=48&Description=&Type=&N=2010380048+1069609642&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=696%3A9642
You need a more larger power supply. The current one is a 145 watt u-ATX Form Factor; you need at least 250 watts in that form factor (size)
A better choice might be a new motherboard. Look for board with a AMD Socket 7 if you want to keep this CPU. The motherboard will need to match the size of the current one to reuse the case. It's a uATX "like" form factor (7.4" x 9.35"). Also plan on a new power supply any AGP or PCI-e video card will want more than 350 watts (for the low end cards). Getting a new computer might be worthwile.
I hope this helps.
Apr 13, 2010 | Gateway Computers & Internet
Bought a corsair vx550 and it doesn't fit. Plus, the motherboard has a 3 prong connector just behind the 20 pin that is not available on the new power supply
The Cosair VS550 fits the form factor Standard ATX PS/2 .
size: 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L).
Do you know what size your case is? I tried the Sony site and their support site which only offers a part number for a replacement power supply (sony part #
146870923)
Mar 28, 2010 | Sony VAIO Digital Studio PCV-RS420 PC...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
My motherboard wont fit into any case ><
all motherboards have a size known as "form factor"
*********** baord is Micro ATX,
youll have to buy a case that can fit that motherboard in or buy another motherboard that will fit in your case, youll have to find out your dell model number to find the form factor, easiest way would be search your old motherboard number
Jun 04, 2009 | Intel D845GVSR Motherboard
Power supply
What you need to be concerned about with Power Supplies is the Wattage (The higher the better) and its "Form-Factor." A Form Factor is the general size and shape of the motherboard. The most commonly used Form Factor is ATX or Mini-ATX. I would reccomend figuring out what size your case is either ATX or Mini-ATX (Baby-ATX sometimes) and you should be able to decided whether the PS is too big. Too small isn't a problem as long as you can screw the unit in tight.
Jan 20, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Gateway GT4010 Problem
This problem is video chip related. I have done alot of research on this and found that everyone has the same problem in some form or another. Your best bet is to junk the pc and get a different one, since the motherboard in the pc and the replacements you can get are all prone to the same failure. The best home remedy I have found is a hair dryer on the video chipset as mentioned in one of the above "fixes". Seems to work for a while, not permanent. You may need to repeat if your system goes down again. Also, when your system powers up and your screen looks more green than usual or different than it used to, just apply more heat and pressure. On another note, if anyone has a replacement for this case, GT4010, from a different manufacturer, please let me know. Hope this helps.
Oct 15, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Computers & Internet Logo
196 people viewed this question
Alun Cox
David Payne
David Payne
