Does 2003 buick lesabre have an access panel in the center of the rear seat that opens to the trunk so skis can fit through. the park avenue has it
In the trunk of the car there is a black panel behind the rear seat remove screws that hold this panel on. There are three magnets at the top of the panel. Remove panel and put screws in safe place. Go back to the inside of the vehicle there are three brackets that hold in top cover of back seat remove that lay it down in the back seat. You now have complete access from the rear seat to the trunk. To reassemble reattach rear seat top. Reassemble black panel in trunk just attach to metal with magnets and then put screws back in. Hope this is helpful and informative.
SOURCE: rear air shocks 2003 Buick LeSabre
I'd have them checked first to determine if it is actually the shocks, or possibly just a loose or cracked line, which should be a pretty inexpensive fix. If it turns out to be shocks, weigh it out then.
SOURCE: Cannot change 3 rear spark plugs on 1999 Buick park avenue
there is a special tool for this job but I have cheated on this but you ned to be careful when doing this.The wishbone shaped mount on the front going from motor to front of vehicle, remove and it allows the motor to tilt.
SOURCE: Remove right rear door panel 2003 Buick LaSabre
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: how do i remove the rear passanger 2000buick lasabre door panel.
SOURCE: How do I remove the rear door panel on my Buick Park avenue
