Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
Having to re-enter shared secret key in client card utility
This wireless card works fine for me apart from one thing: Everytime I restart the PC I have to re-enter the wireless network key into the client utility or I can't connect to the internet. Is there any way I can make the client remember it? Thanks
  • jra evans Mar 22, 2007
    Hi, thanks a lot for your quick and very thorough reply. Unfortunately I should have mentioned that I am running Windows 98SE... Does this operating system use a similar utility to the XP one you have mentioned? Thanks again.
    (I put that as a solution by mistake...)
I have the same problem; with my Laptop + original 2wire card and PDA + socket wireless card My laptop wireless worked fine for month, then happened what you discribed- had to enter the WEP key each time after rebooting. With the PDA it helped to choose "connect" to one of the found networks. If you have several connection possibilities (networks) you may choose "connect" manually each time. My PDA needs a very long time to connect (while I'm playing around, it says "connected", but the Link LED still just blinks) I have the suspicion, that you have to connect/login to 2wire first to initialize the connection and have it permantly. But I agree that their is not enough context sensive help popup, the phone support does not know much either The key(like any password), will always be asterisked out
Posted on Jun 08, 2007
Thanks again for the reply. I've reinstalled the drivers a few times (and actually reinstalled Windows too) but it still does the same. When I click on the box in the utility where you enter the network key, the key is still there asterisked out, but I have to enter it again and refresh before the card reconnects to the network and lets me connect to the Internet. Maybe I should contact 2wire directly via their website because it seems like a problem with their software, although looking at some pages in Google I haven't found anyone else with this same problem :(. Thanks for your help anyway.
Posted on Mar 22, 2007
    Scholar:
  • 113 Answers
With the description you have provided, I presume that you are using Windows XP. Now, whenever we use utilities to manage wireless adapters, they always conflict with the Wireless Zero Configuration (A service in Windows XP which manages your wireless adapters) and mostly your utility is not able to retain the settings provided to it. The best solution would be to disable the Utility and use the Wireless Zero Configuration instead. We can do that by right clicking the icon for the utility which must be available in the system tray (on the right bottom corner of the computer srceen) and there must be an option which says something like - 'use windows to manage the wireless adapter'. Once we do that, we need to make sure that the Wireless Zero Configuration is actually enabled. Please follow the following steps. STEP 1: 1. Click on start -> run 2. Type 'services.msc' and click OK 3. This will display a list of services 4. Try and locate the 'Wireless Zero Configuration' in the list 5. Double click on it 6. Make sure the 'Startup type' is set to 'Automatic' and the status is 'Started' STEP 2: 1. Click Start -> Control Panel 2. Locate the icon - Network Connections (when in classic view) 3. Under Network Connections, right click on the 'Wireless Network Connection' and click on 'Properties' 4. Look for the 'Wireless Networks' tab 5. Look for the check box which says 'use windows to configure the wireless network settings' Any further questions or issues, please get back to me. good luck
  • Sandeep Bakshi
    Sandeep Bakshi Mar 22, 2007
    Windows 98 SE does not have any such utility. We need to rely on the Wireless utility only.
    It seems like we are having issues with the utility you are using. We need to reinstall the drivers and the utility. Also, you can install the latest drivers from...
    http://www.wireless-driver.com/wifi/2006...
WAP/WEP password not working
These are the two options for your Router. Don't forget to save your settings
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard for securing your wireless network. If you would like to secure your wireless network using WPA, you will need the following:
  • WPA enabled on your Dell TrueMobile 2300 Wireless Broadband Router
  • WPA support for your wireless clients. If you are using a Dell TrueMobile wireless client, you can check for the availability of WPA enabled software update for your wireless client at http://support.dell.com.
  1. Log into the Web configuration of your router at http://my.router (or the default address http://192.168.2.1)
  2. Click on Basic Settings.
  3. Click on Wireless Security.
  4. Click on the Enable Wireless Security checkbox.
  5. Select either WEP or WPA in the Network Authentication list.
To setup WPA
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key rotates or changes.
  4. WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports.
  5. Click NEXT, then Save and Restart to apply the changes.
  6. Setup the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients on-line help system for information on how to setup WPA.
May 14, 2012 | Dell TrueMobile 2300 Wireless Broadband...
Tip
Windows problems connecting to WPS enabled routers
You may come across connection problems when routers have Wi-Fi Protected Setup (WPS) enabled and clients do not support it.
In Windows XP, Wireless Zero Configuration (WZC) may mistake a WPS enabled router for a WPA-Radius protected one and warn you that there is no certificate to connect to it:
To work around this problem, you can either disable 802.1x authentication on the client or disable WPS on the router's.
802.1x on the client can be disabled in the properties of the wireless network. On the Authentication tab, untick the 802.1x Authentication option. Make sure that the correct encryption type is selected on the Association tab and that the WPA Pre-Shared Key or the WEP key is entered.
On Windows Vista things may even be worse. When you try to connect to a WPS enabled network, Vista may prompt you for a user name, password and domain name as if PEAP authentication were used. When you manually create the network profile specifying WPA2-PSK, AES and the Pre-shared Key, Vista may refuse to connect stating that the network profile does not match the actual configuration. The only work-around in this case is to disable WPS on the router.
To disable WPS on the router, go to the Wi-Fi Protected Setup.
To learn how to disable WPS click here...
At the top of the page, just set WPS to disabled and apply changes. You may need to delete the profile for the network on the client card before it can connect to the router.
on May 05, 2010 | Computers & Internet
How do I secure?
WIRELESS To configure the Router as a wireless access point for wireless clients (either stationary or roaming), all you need to do is define the radio channel, the Service Set identifier (SSID), and security options.ADVANCED SETUP 47 Channel and SSID You must specify a common radio channel and SSID (Service Set ID) to be used by the Router and all of your wireless clients. Be sure you configure all of your clients to the same values. SSID: The Service Set ID. This should be set to the same value as the other wireless devices in your network. SSID Broadcast: Broadcasting the SSID on the wireless network for easy connection with client PCs. For security reasons, you should disable SSID broadcast. (Default: Enable) Note: The SSID is case sensitive and can consist of up to 32 alphanumeric characters. Wireless Mode: Set the communication mode for the Router. Default: Mixed (11b+11g)Configuring the Wireless Barricade g Router 48 Transmission Rate: Set the rate of data transmitted from the Router. The lower the data rate, the longer the transmission distance. (Default: Fully Automatic.) Channel: The radio channel through which the Router communicates with PCs in its BSS. (Default: 6) Note: The available channel settings are limited by local regulations. g Nitro: In a crowded 2.4 MHz frequency, the connection speed is much lower than the promised 54 Mbps. The g Nitro implemented by Intersil's Prism Nitro technology dramatically enhances your wireless network speeds. It provides up to 50% more throughput in 11g only environment, and improves network throughput by 3 times in mixed mode.ADVANCED SETUP 49 Security If you are transmitting sensitive data across radio channels, you should enable wireless security. Configuring the Wireless Barricade g Router 50 WEP Wired Equivalent Privacy (WEP) encryption requires you to use the same set of encryption/decryption keys for the Router and all of your wireless clients. WEP mode: You can choose disabled, 64-bit or 128-bit encryption. Key Provisioning: Select a key type of static key or dynamic key. Static WEP Key Setting You may manually enter the keys or automatically generate encryption keys. To manually configure the keys, enter 10 digits for each 64-bit key, or enter 26 digits for the single 128-bit key. (A hexadecimal digit is a number or letter in the range 0-9 or A-F.) For automatic 64-bit security, check the box of Passphrase, enter a passphrase and click SAVE SETTINGS. ADVANCED SETUP 51 Four keys will be generated. Choose a key ID (1-4) from the drop-down list or accept the default key. If you use encryption, configure the same keys used for the Router on each of your wireless clients. Note that Wired Equivalent Privacy (WEP) protects data transmitted between wireless nodes, but does not protect any transmissions over your wired network or over the Internet. WPA Wi-Fi Protected Access (WPA) combines Temporal Key Integrity Protocol (TKIP) and 802.1x mechanisms. It provides dynamic key encryption and 802.1x authentication service. With TKIP, WPA uses 48-bit initialization vectors, calculates an 8-byte message integrity code, and generates an encryption key periodically. For authentication, it allows you to use 802.1x authentication for an environment with a RADIUS server installed on your network. Selecting the Pre-shared Key enables WPA to use the pre-shared key in a SOHO network.Configuring the Wireless Barricade g Router 52 Field Default Parameter Description Cypher suite TKIP One of the security mechanism used by WPA for frame body and CRC frame encryption Authentication 802.1X Select the authentication mode. • 802.1X: It is for an enterprise network with a RADIUS server installed. • Pre-shared Key: It is for a SOHO network without any authentication server installed. Pre-shared key type Passphrase (8~63 characters) Select the key type as in pass-phrase or in 64-Hex characters Pre-shared Key none Specify in pass-phrase style or in 64-Hex characters. Group Key Re_Keying Disable The period of renewing broadcast/ multicast keyADVANCED SETUP 53 802.1X Management access will be checked against the authentication database stored on the Router. If an authentication RADIUS server is used, you must specify the secret key of the Message-Authenticator attribute, i.e., Message Digest-5 (MD5), and the corresponding parameters in the RADIUS Server Parameters field for the remote authentication protocol.Configuring the Wireless Barricade g Router 54 • General Parameters • RADIUS Server Parameters Field Default Parameter Description Enable 802.1X Yes Starts using 802.1x security control. Session Idle Timeout 300 seconds Defines a maximum period of time for which the connection is maintained during inactivity. Re-Authentication Period 3600 seconds Defines a maximum period of time for which the RADIUS server will dynamically re-assign a session key to a connected client station. Quiet Period 60 seconds Defines a maximum period of time for which the Router will wait between failed authentications. Server Type RADIUS Selects the authentication server type. Field Defaults Description Server IP 192.168.1.1 The IP address of the RADIUS server. Server Port 1812 UDP port is used for RADIUS authentication messages. Secret Key none Defines a text string on both the RADIUS client and server to secure RADIUS traffic. The RADIUS server requires MD5 Message-Authenticator attribute for all access request messages. The 802.1x authentication scheme is supported by using the Extensible Authentication Protocol (EAP) over the RADIUS server. NAS-ID none Defines the request identifier of the Network Access Server
Source: http://www.smc.com/files/AK/2804WBRP-G_MN.pdf
Please leave feedback for this answer, thanks.
Mar 10, 2011 | SMC Barricade g SMC2804WBRP-G Wireless...
I have my network open and i wish to put a password on it.. how do i do that?
Hi.
First, you need to access your router.
To do this, open a browser, and in the address bar type in: 192.168.1.1
This takes you inside the router's web access program.
From here you can change settings like security.
here as all the instructions for changing it.
  1. Type the following text in the user name and password fields: "admin".
  2. Go to the Basic Settings menu option tab on the top navigation bar and wait for the menu to appear.
  3. Click the Wireless Security menu option in the drop down menu.
  4. Click to select Enable Wireless Security.
  5. Click to select either WEP or WPA in the Network Authentication list.
If WEP is selected
  1. Select hexadecimal or ASCII characters as the Key Format. You can use either as a string of hexadecimal digits (characters 0 through 9 and A through F ) or as ASCII characters (any key on the keyboard).
  2. Select an encryption level from the Key Length list.
  3. Enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router. For 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits) WEP key. For 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key.
  4. Select only one key out of the four keys as the Default Key for encryption.
  5. Click the NEXT button, and then click Save and Restart to apply the changes.
  6. Set up WEP encryption on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients' on-line help systems, for information on how to set up WEP encryption.
If WPA is selected
  2. Choose a key format. This can be hexadecimal digits (0-9 and A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key "rotates" or changes.
  4. WPA Encryption allows you to select one of two possible encryption methods-TKIP and AES. Choose one that your wireless clients support.
  6. Set up the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients' on-line help system, for information on how to setup WPA.
I know it looks like a lot of information, but really it's not.
Just follow these steps and you're security eill be set up in no time, and then you can rest your fears about someone else using your network without your permission.
NOTE:
NEVER store the password in your computer, because in the event of an infection, that information could be stolen.
Write whatever your new password is down, and keep it safe somewhere. That way, if someone does want to use your network, they will have to ask you for it, and you will have it for them.
I hope this gets you going the way you want!
Feb 08, 2011 | Dell Wireless 2350 Router
I have a DIR-625 N router and am unable to secure it
Hi dakingma1221,
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
You may also connect using the NetBIOS name in the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. Type in the graphical authentication code (if you cannot read it, click Regenerate).
To run the security wizard, click on Setup at the top and then click Launch Wireless Security Setup Wizard.
Click Next to continue.
Enter the SSID (Service Set Identifier). The SSID is the name of your wireless network. Create a name using up to 32 characters. The SSID is case-sensitive.
Select the level of security for your wireless network:
• Best - WPA2 Authentication
• Better - WPA Authentication
• None - No security
If you selected Best or Better, enter a password between 8-63 characters.
If you selected Good, enter 13 characters or 26 Hex digits.
If you selected Better, the following screen will show you your Pre-Shared Key to enter on your wireless clients.
Click Save to finish the Security Wizard.
If you selected Best, the following screen will show you your Pre-Shared Key to enter on your wireless clients.
If you selected WPA-Enterprise, the RADIUS information will be displayed. Click Save to finish the Security Wizard.
Good Luck,
Don't forget to leave a rating,
Thanks
Mark
Sep 18, 2009 | D-Link DIR-625 (790069292637) Wireless...
MSI
The Pre-shared key is used to setup encryption on wireless routers.
The latest strongest encryption methods used is Wi-Fi Protected Access (WPA and WPA2).
The wireless router is configured with WAP or WAP2, and the computer's wireless card is configured with the router's WAP or WAP2 encryption. The wireless router will now allow communication with the computer's wireless card, data transmitted between the router and computer is encrypted and therefore protected from unauthorized access.
Sep 08, 2009 | MSI Wireless-G RG54G3 Router
Linksys Rangeplus wireless adapter not connecting
hmmm....
you are getting an incorrect ip address so what we need to do is to reconfigure the wireless profile,
open up the linksys utility and go to the tab that says profile,you will see the profile that you have configured earlier,
click on the profile and click on remove once the profile is removed ****,go to the tab that says site survery...
click on your network and then click on connect it will take you through a setup screen,then choose the security whether it is wep/wpa and down below choose the bit type if the security key has 10 characters then it is 64bit and if it is more than 10 characters then 128bit....donot put the passphare to generate a key,directly punch in the number..
****1 more step you can perform before creating a new profile is go to start,run in the box type in cmd and then open the black box then type in netsh winsock reset catalog and then hit enter it will tell you to restart the computer,restart the computer and then try creating a new profile...make sure the internal wireless card is disabled when you create a profile..
hope this works for you...
vedhick
Feb 06, 2009 | Linksys Rangeplus Wireless Pc Adapter
Cisco aironet 350 - media disconnected
does your laptop have a switch on the side or Fn key (blue icons on the F keys) to turn on/off the wifi.
Sometimes Fn + F2 will toggle the wifi on/off.
Post your make/nodel laptop and OS for more specific advice
I avoid using client utilities with wifi. In the conection "allow windows to manage connection" and see if you can connect
Jul 10, 2008 | Computers & Internet
Secure network
- access your web user interface by typing http://my.router (or the default address http://192.168.2.1) on the address bar of your web browser
- click on Basic Settings
- click on Wireless Security
- click on the Enable Wireless Security checkbox
- select either WEP or WPA in the Network Authentication list (Note: make sure that your wireless computers can support wpa if you're planning to use wpa. wpa is more secured than wep)
if you're going to setup wep, follow the steps below:
- select hexadecimal or ASCII characters as the Key Format, you can use either as a string of hexadecimal digits (character 0 ~ 9 and A ~F ) or as ASCII characters (any key on the keyboard)
- then select your desired encryption level from the Key Length list. it could be either 40(64)-bit or 104(128)-bit key length.
- enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router.for 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits).for 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key (note: you'll just need to enter the characters that you've setup on Key1 for all the wireless computers that you have
- click NEXT, then Save and Restart to apply the changes
if you're planning to enable wpa, follow the steps below:
- enter your pre-shared key. this key must match the key that is used by each wireless client computer associated to your router.
- choose a key format. this can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard)
- WPA Group Rekey Interval specifies how often the key "rotates" or changes
- WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports
then connect your wireless computers to your wireless signal using the correct wireless security (network key)
hope this'll help you.
Jun 08, 2008 | Dell TrueMobile 2300 Wireless Router...
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
238 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
