Adding extra internal hard drive.
How to add extra internal hard drive to acer aspire AM5621 desktop pc
    Problem Solver:
  • 7 Answers
Make sure you pc is turned off before you start. To add additional internal hard drive you will need to get SATA hard drive. when you open up your pc there will be a slot to put it in. on the new hard drive there will a display with shows you how to make that hard drive a slave. move the little thing to the right place and plug it in. when you restart it should read it .
Posted on Dec 16, 2008
I have Acer Aspire E500 (ASE500-UP801M) running Win XP Media Center edition, 1G RAM. It is too slow. Q1. Could I add another RAM stick to it and how much maximum could I add? Q2. How do I know the Bus
Test your computer using a brand new hard drive. 1GB memory is enough. I am sure this is a software problem (messy registry or problematic apps or malware) or space problem (the hard drive is almost full).
Feb 27, 2014 | Acer Aspire E500 PC Desktop
I try the hard drive in another computer and works fine
Internal or external. Details always help.
Internal - Check the BIOS.
Oct 24, 2012 | Acer Aspire AX3400-U2022 PT.SE202.007...
How to install hard drive
First unplug power and leads including internet, then you will need a screw driver to get the side cover off, make sure to touch a bare metal piece to prevent static discharge. unclip the sata cable and power from the hard drive, unscrew the fixture screws holding the hard drive in place, remove and replace with new hard drive....or of you are adding another for extra storage look for a vacant bay to house the new drive, there should be a spare power lead for the drive but you may need to purchase another sata lead if you dont have one, attatch the sata lead to the motherboard then attatch the other end to the hard drive then the power lead. Close the lid and re-boot, the new drive should be picked up by windows 7 or vista, if you have installed a new drive with no operating system you will need a bootable op disc
Cheers
Sep 23, 2012 | Acer Aspire M3641 Dual Core E2200 PC...
Can the acer aspire use a 2tb internal hard drive
Anny PC can take a 2tb hdd along as you enable it in the bios also on that note check for overheating on ether your internal graphic chip or card as overheating will cause that problem
Jun 19, 2012 | Acer Aspire Ax1700 Dual Core Desktop Pc
Is there instructions on how to add a second sata internal drive to my new desk top pc.
yes there is pls. go to this link as it will give you the instructions on how to add additional SATA Hard drives.
http://www.wikihow.com/Add-an-Extra-Hard-Drive
Mar 06, 2011 | HP Computers & Internet
Hi, I bought a new PC desktop Acer Aspire Vista, but from the start I had a problem with this machine. It worked properly for about one week then it starts to freeze. When I try to switch it off, or...
Honestly, it could be almost anything. It takes a few software tests in order to see if it is in fact hardware related.
I would recommend some tests.
www.malwarebytes.org
www.superantispyware.com
And although it's not free, PC Toolses, pop out the memory and make sure it's set right etc.s Registry Mechanic
Chances are this could fix a variety of things.
More than likely hardware related but if you upgraded to Win 7 without formatting, something could still exist on the hard drive causing this.
If all else fails, open the ca
Mar 02, 2011 | Acer Aspire AM5621-EQ9300A (PT.SB50X.004)...
How can i add additional hard disk in to my acer aspire 6930g , I tried to do it but the cover doesnot close after putting the hardisk into the laptop, Any solution?
Or you guys could stop being ******* RETARDS and learn that Acer 6930G actually has second drive bay in lower left corner for installing secondary hdd.
You will need to get two(three counting connector) extra parts from Acer though: new cover (old one doesn't fit, metal mounting plate and connector.
Jan 08, 2010 | Acer Aspire 6930-6771 Laptop
How to repair and remove blue screen in Acer Aspire M5641
The resolution depends on *why* you're getting the blue screen. Start by disconnecting all of the drives, USB devices, and other peripherals. Connect just the monitor, power up, and see if it blue screens. If that works, next add just one RAM module and see if it blue screens. Then, add just the main hard drive and see if it blue screens. Keep adding one device at a time until you find the one that's causing the blue screen error. Once you've identified the bad part, get back to us, and we can discuss diagnosing or replacing it.
Oct 31, 2009 | Acer Aspire M5641 PC Desktop
Apire T180 - Adding hard drive
Thjis PC has a SATA (serial) drive. You have to purchase a SATA cable and a SATA power cable. Then you can install it on the SATA 2 port on the motherboard.
You can buys these at your local computer store or at Cyberguys.com:
http://www.cyberguys.com/templates/SearchAll.asp?search=sata+cables&sort=desc
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 01, 2008 | Acer Aspire T135 PC Desktop
Computers & Internet Logo
660 people viewed this question
Alun Cox
David Payne
David Payne
