Question about Kenmore 22422 Top Load Washer
My 800 series Washer get frozen Y want to take out the back side
I have one Kenmore Washer machine that get frozen inside , so I need to open it to warm it up. Thanks
Fabio
JUST LIFT THE COVER UP AND USED ONE HEATER TU WARM IT UP HOWEVER THE HOT WATER DOSE NON STOP INTAKEN WATER MAY YOU HAVE SOME THING TO TELL ME ABOUT THIS ISSUE.
Fabio
Posted on Dec 18, 2008
How do you get the top off of a kenmore 800 series washer and also the back???
The top or the back does not come of //your post is a little old so if you still need help please ask and I will tell you how to take machine apart......
Feb 07, 2011 | Kenmore Washing Machines
I have a kenmore 80 series washing machine. During the second cycle it stopped working. It won't drain or spin. What should I do?
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 10, 2011 | Kenmore 24902 Top Load Washer
My Kenmore 800 series washer is leaking water all over the floor and i can't find where its coming from. It only leaks when its on and running. I tried to take the back of it off to see where it was coming...
Some of theses models have a tendency of leaking out the side of the pump housing. In this case you will need to replace it. Here is a link to help disassemble and acess the pump.
Disassembling a whirlpool style washer
Oct 13, 2010 | Kenmore 22422 Top Load Washer
Washer fills agitates and drains but wont spin kenmore 800 series
sounds like you need a drive coupling. tip the machine back and remove the motor and pump. the coupling is between the motor and gearcase.
Feb 07, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
Sep 05, 2009 | Kenmore 24902 Top Load Washer
My duet washer is locked and will not reset
To open the door,remove the bottom panel. Teach up inside on the lock side and find the pull ring. Pull on the ring while putting pressure on the door. It will open. Have the door lock wax motor and mechanism replaced.
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 series washer does not drain
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
2. Water Pump
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Kenmore 22422 Top Load Washer Logo
155 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
