Question about Samsung ML 1610 Laser Printer
Toner exhausted hi,my cartridge after refilling showed above message,then i send it back to the person who did it and he orderd a new cartridge but the same problem exists yet. i can take printer self test but it shows TONER EXHAUSTED message when i want to print through computer and also on the self test printed page.i want to know if reseting the printer solve the problem.if so please tell me how can i do that. i'm looking forward to get your reply.thank you. Hirbod
  • Anonymous Jan 22, 2009
    toner exhausted
    Problem Solver:
  • 10 Answers
Have you fitted a reset fuse on the cartridge?
Posted on Oct 05, 2009
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
SHOWS A MESSAGE THAT TONER EXHAUSTED , CAN'T TAKE PRINTS AND XEROX
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 28, 2011 | Samsung SCX-4300 Monochrome Laser...
I RECEIVE TONER EXHAUSTED MESSAGE AND I AM NOT ABLE TO OPERATE MY PRINTER. MY PRINTER MODEL IS SAMSUNG SCX-4300 SERIES
May 10, 2011 | Computers & Internet
I will refil toner but message showing toner low. please solve my problem.
Mar 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Sir I Have Problem with SAMSUNG All In One SCX 4623F .It shows Toner Exhausted Mesaage.Can u send me the software or instructions to reset this printer.or any permanant solution u have in this case. i...
Hmmm... how about refilling the toner!
Those new printers don't work w/o cartridges and ink!
The cheapest way is go to ur nearest INK REFiLLiNG STATiON w/ ur toner cartridge!
Nov 20, 2010 | Computers & Internet
I have got my samsung 4300 toner refilled,and the display shows toner exhausted .the person who got my toner recharged told me that samsung 4300 printer has some inbuilt chip,which needs to be changed...
Hi
The person refilling your toner needs to install the correct chip onto the toner cartridge. The chip stores the number of pages printer by that cartridge and is unique to each model printer, therefore an incorrect chip will not work. Good luck with that
Oct 06, 2010 | Samsung SCX-4300 Monochrome Laser...
Two months back, I bought Samsung SCX-4300 printers. Uptil now, it yielded only about 800 prints and now started giving indication that "toner is low". Should I go to replace the introductory toner with a...
The problem is that Samsung wants you to buy a new cartridge every time you get "toner low" or "toner exhausted"message but..there is a solution :
You have to flash the printer with a fixed firmware so that you can just refill the toner cartridge and continue printing :) The procedure will take about 5-6 minutes if I am do it personally ( for this to happened i need you to press a combination of buttons on the printer to get into TECH MODE and then I need access to your computer and printer CONNECTED to it so I can upload the new firmware to the printer - this is because if i have to explain to you the whole procedure it is going to take me a far more time than i have to spend on this. If you want me to help you i will give you a details how we can do this exactly...if not...go buy a new toner cartridge :)
May 23, 2010 | Samsung SCX-4300 Monochrome Laser...
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Samsung ML 1610 Laser Printer Logo
222 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
