Question about Vacuums
Dirt devil vaccum #088915 won't pick up.
My dirt devil won't pick up. any suggestions?
    Problem Solver:
  • 7 Answers
Well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Posted on Dec 17, 2008
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
It is a dirt devil Royal which I use to vaccum stair steps. it is a new vaccum . not it will not work, the brush will not rotate. I looked to see if some hair was the problem but no hair or fuss. ...
Hi, I am sorry it took this long to get back to you and I promise I will get right on this. We are having issues with our e mail notifications.
You say this is a new vacuum, do you mean brand new? never used before? I am going to look into the dirt devil problems and see if we can narrow down the causes. I assume you tried this in several outlets to make sure it is not the outlet. Does the motor run at all? or is it running but the brush not turning and not picking up dirt.?
Nov 07, 2011 | Vacuums
The vaccum won't pick anything up
You have a clog in the dirt path ... Inspect and clean it from end to end. You will probably need a broom handle and a screwdriver.
May 01, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
How do you replace the belt on the dirt devil feather lite vaccum.
not a expert just trying to help,,turn vaccum over take plate of and pull brush out and install new belt,,hope this help you
Oct 20, 2009 | Dirt Devil CE6100 Featherlite Upright...
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
I have a handheld vaccum that has quit picking up anything I try to clean
I've cleaned out the vaccum, now it's working, but thank you
Sep 28, 2008 | Dirt Devil Vacuums
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
286 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
