Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Kenmore dishwasher model #665-16751791
After I ran my dishwasher I opened it up and found a blue gasket type ring on the top rack. It was shaped like an oval. I had a repairman look at it and he couldn't find where it came from, could you please help me? Thanking you in advance for your help. DJ Serial #fg4603546
  • Anonymous Jul 09, 2008
    I just had the same problem with my Kenmore model 665.15529000. Only my blue rubber oval ring was at the bottom of the dishwasher. I am completely baffled by what it could be. Does your dishwasher continue to work fine? I haven't tried mine yet for fear it will flood the house.
    Scholar:
  • 76 Answers
Nickysoma What ever you found does not belong to the dish washer. Keep use your machine. It is nothing to worry about. Gendos...post back
Posted on Mar 23, 2007
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
Kenmore DW model 15999 Lower Spray Tower Came off
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Nov 22, 2008 | Kenmore 24 in. 15999 Built-in Dishwasher
Top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Kenmore Elite Dishwasher 16939
I have the same model dishwasher with same problem. The gasket first came loose just after my warranty expired. The stainless steel and heat don't make for a good combination with the glue that holds the gasket in. My husband works with caulk and the like. He found a clear gel of some sort to get everything to adhere. It's had to be reapplied. I just make a habit of making sure the gasket is seated in its track and watching if dishes on top rack catch the gasket when I pull rack out.
See www.repairclinic.com, item #1065754, White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets. It's an accessory for this dishwasher. I don't know if Sears Parts Direct offers it. Sometimes their price is lower.
From above website it costs $14.55
Dec 12, 2007 | Dishwashers
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
289 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
