Question about Whirlpool GD2SHGX Refrigerator
Whirlpool refrigerator ED22TEXHW01 ice maker
The ice maker in my Whirlpool refrigerator is not making ice. The arm lifts like it is dumping ice into the bin, but there is no ice to dump. I believe the problem is in the water supply, but not sure. I have through the door ice dispensing with a water dispenser and I can get water through the door dispenser. I took the cover off of the ice maker and the gear goes around as it goes through the cycle of dumping ice. The arm lifts during the dumping process and drops after the ice supposedly has dumped. I don't see any water coming through the tube at the top of the ice maker.
  • 8 more comments
  • Anonymous Mar 16, 2014
    The door dispenser does have the water dispenser working. The ice maker ejector arm actually goes around every few minutes. I don't hear the usual clicking to let more water in, and no water is going into the tray. How to I test the water valve to verify it is functioning? And/or if there is water getting to the valve, but I know water is getting to the fridge door dispenser.
    Installed new water line and 5 days later water quit dispensing from the refrigerator. Not sure if ice maker still works. Where to start diagnosis?
  • Anonymous Mar 20, 2014
    the ice bin is empty and the ice maker is not dispensing more ice
  • Anonymous Mar 21, 2014
    jbnd-26 makes ice but will not dump the ice through the door.
  • Anonymous Mar 23, 2014
    Ice bin just turns slightly then back to normal
  • Anonymous Mar 28, 2014
    alram is ringing during night time
    ice maker is making a cracking noise and the arm doesn't shut the ice maker off. and is not making ice. what do i need to do
    the ice maker is making a crackling noise and the arm doesn't shut the ice maker off. I ice maker doesn't make any ice. what do i do
  • Anonymous Mar 29, 2014
    The ice maker is full and the ice is frozen. The bin has been cleared and cleaned. The ice maker is on but the ice will not drop
  • Anonymous Mar 31, 2014
    ice emptied out arm stuck up. Can't get the arm down to continue making ice.
    President:
  • 878 Answers
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
Why does Whirlpool G16FARXXF05 refrigerator not dump the ice?
as I remember them there is a small heater that warms the bottom of the ice maker so the ice is loosened a little perhaps your timer or heater has gone kaput
Jul 20, 2015 | Whirlpool Refrigerators
On off switch for ice maker
The wire arm that travels up ad down when it dumps ice. Lift the arm to the horizontal position and it should stay there. The ice maker is now off. Push the arm back down and the ice maker is on.
Mar 01, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not dumping...the ice is freezing but not emptying.
Make sure the arm is down on the ice maker. There is a heating element that warms the ice tray slightly so it can break the ice loose and dump. If the element is bad it would be best to buy a new ice maker. They run from 68 dollars and up. good luck
Aug 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool model # ed2chqxkb05 is not making ice, we can still use the water in the door. its not making ice. Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore refrigerator side by side ice maker not making ice.no water going to the ice maker??.
Sep 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool Gold Side by Side Ice maker not making ice.
Aug 31, 2009 | Whirlpool GS6NBEXR Side by Side...
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Refrigerator will not dump ice.
I hate ice makers. Try putting a glass or something to keep the bar from going all the way down.
Apr 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GD2SHGX Refrigerator Logo
773 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
